Lpc2000
arm-elf-ld trouble
arm-elf-ld trouble
2006-05-26 by dgaydou
Hi group,
i`m doing my first steps with LPC2114 and gnuarm. I�ve found a trouble
when i try to link the objects files from c-sources and as-sources with
arm-elf-ld and the following parameters : -Map main.map -TPruebaLPC.ld -
t. The linker tell me: Undefined reference to `THOSE FUNCTIONS THAT ARE
WROTE IN ASSEMBLER`; although i�ve declared those functions in my
headers files and properly included. Hope someone can help me. Thanks.
Re: arm-elf-ld trouble
2006-05-26 by brendanmurphy37
--- In lpc2000@yahoogroups.com, "dgaydou" <dgaydou@...> wrote:
> Hi group,
> i`m doing my first steps with LPC2114 and gnuarm. I´ve found a
trouble
with
TPruebaLPC.ld -
THAT ARE
> WROTE IN ASSEMBLER`; although i´ve declared those functions in my
Thanks.
Do you have the assembler directive ".global" in the assembler
source file? Without it the function name is not visible to the
linker. This behaviour is different from 'C' in that the default is
NOT to make function names visible.
Example:
/* list functions exported from this file */
.global	GetCPSR, SomeOtherFunction
/* implementation of GetCPSR */
GetCPSR:
    mrs  r0, cpsr  /* Get CPSR */
    bx   lr        /* return to caller */
This can be declared in 'C' as:
unsigned int GetCPSR(void);
and used as:
unsigned int cpsr = GetCPSR();
My guess is that this is your problem.
Brendan
2006-05-27 by dgaydou
i´m afraid, i´ve already done it, as you tell me in your example. It
must be something else... another idea, please.
Thanks for your help
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
<brendanmurphy37@...> wrote:
> --- In lpc2000@yahoogroups.com, "dgaydou" <dgaydou@> wrote:
> > Hi group,
> trouble
sources
> with
> TPruebaLPC.ld -
> THAT ARE
> Thanks.
> Example:
> GetCPSR:
> and used as:
> Brendan
16x2 Lcd problem
2006-05-27 by omkar vyas
hi,
i have interfaced lcd to lpc 2104
-> problem is when i send data on lcd above 0x49
its DB7 bit of lcd get set that is logic high! so i get some display of higher ascii characters
in short any characters above "I" does not get displayed instaid original sent character with DB7th bit set get printed how to clear that bit???
i mean i am messing with some settings or what!
Please help me soon!
thankx!
Be a chatter box. Enjoy free PC-to-PC calls  with Yahoo! Messenger with Voice.
Re: [lpc2000] 16x2 Lcd problem
2006-05-27 by Peter Jakacki
omkar vyas wrote:
> hi,
No. 5 is alive! need input, need input ....
please input hardware & software details for analysis >
We could just guess one of the thousands of different ways that an lcd
could be connected up and then also guess the exact code you used I suppose.
*Peter*
hi ,
Peter, Thankx
i am sending all related files with this mail
c firstly in arch.h i have data structure u can find all definations also
in system.c ->delay n all routines
in lcd.c->all functions related to lcd
in init.c->all peripherials init
in main .c i am calling all functins!!!!
Peter Jakacki <peterjak@...> wrote:    omkar vyas wrote:
 > hi,
 *Peter*
        SPONSORED LINKS
                                                    Microcontrollers                                       Microprocessor                                       Intel microprocessors
   YAHOO! GROUPS LINKS
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
Re: [lpc2000] Re: arm-elf-ld trouble
2006-05-27 by Richard Duits
Make sure the identifier from your error message is exactly the same as
the identifier after the .global. I used to code x86 assembler in masm
or tasm and there you had to prefix the identifier with an underscore (
_ ). When I started with ARM also did this and it gave the same errors
you are getting now.
Make sure you use extern "C" { ..... } if you are coding in c++,
otherwise the identifiers are decorated (to make overloading possible
and add some extra error checking).
Richard.
dgaydou wrote:
> i\ufffdm afraid, i\ufffdve already done it, as you tell me in your example. It
> > > Hi group,
> > > i`m doing my first steps with LPC2114 and gnuarm. I\ufffdve found a
> > trouble
> sources
> > with
> > TPruebaLPC.ld -
> > THAT ARE
> > > WROTE IN ASSEMBLER`; although i\ufffdve declared those functions in my
> > Thanks.
> > Example:
> > GetCPSR:
> > and used as:
> > Brendan
> SPONSORED LINKS
> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=c-HXthtbZy4TZbI3ib0PMg>
> 	Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=ijt0SspWtjogcHCuFD0lUQ>
> <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&c=3&s=69&.sig=WOZdpklkgHbXR5quAgrl5w>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
same as
masm
underscore (
errors
It´s verified, there is absolute coincidence. I´ve pased -
y "Problematic function" to the linker, and it confirms that they are
declare properly in those assembler object files. I´ve also made
tests with underscores (_), and it didn´t work.
possible
I´m coding in "C", I´ve declare the functions: extern void
ProblematicFunction (void);
I´ve brought together some .c and.s files plus a makefile in a folder
to debug this problem. I could upload or email it if someone wants to
test and see the problem. I´m sure i´m making an obviously mistake :).
Thanks again.
> Regards,
> Richard.
It
> > > > Hi group,
> > > trouble
> > sources
> > > with
> > > TPruebaLPC.ld -
> > > THAT ARE
in my
> > > Thanks.
default is
> > > Example:
> > > GetCPSR:
> > > and used as:
> > > Brendan
> > SPONSORED LINKS
> > Microcontrollers
> > 	Microprocessor
> > YAHOO! GROUPS LINKS
2006-05-27 by rtstofer
If ld can't find your functions, maybe you aren't including the object
file on the ld command line.
I have crt.o (the object file from crt.s) as a searate object in my
linker line:
LDSCRIPT  = lpc2106-FLASH.ld
LDFLAGS   =  -Map ${TARGET}.map -T${LDSCRIPT}
LOCATION  = /usr/local/arm
LD        = ${LOCATION}/bin/arm-elf-ld
OBJS      = main.o ata.o conio.o controller.o dir.o fat.o files.o \
            i2c.o interrupt.o ioports.o setup.o spi.o timer.o
${TARGET}.elf : ${LDSCRIPT} crt.o ${OBJS}
	        ${LD} ${LDFLAGS} -o ${TARGET}.elf crt.o ${OBJS} ${LIBRARIES}
All of the OBJS are from C files, crt.o is the only object file
created from assembly language.
There is no problem with ld, almost everybody links an assembly
language startup file.
Richard
2006-05-27 by brendanmurphy37
As a general suggestion, try and get something very simple working,
and work from there. In this case, I'd suggest:
- one 'C' file, with one function
- one assembler file, with one function
- one link file to link the two
Does that work?
If no, then you have something simple to figure out what's wrong
(try posting the relevant files here, and I'm sure someone will
suggest something).
If yes, then try adding stuff a bit at a time until you're back to
where you started from.
This is a general, well-known and effective strategy for locating
the source of problems.
A couple of more specific suggestions:
- does the linker require files to be in order? if so, then maybe
the file order is wrong
- are you 100% sure it's picking up the right files from the right
locations?
Brendan.
> same as
in
> masm
> underscore (
> errors
are
> possible
folder
to
mistake :).
> Thanks again.
> > Regards,
> > Richard.
example.
> It
> > > > > Hi group,
found a
> > > > trouble
> > > sources
> > > > with
> > > > TPruebaLPC.ld -
FUNCTIONS
> > > > THAT ARE
functions
> in my
me.
> > > > Thanks.
assembler
> default is
> > > > Example:
> > > > GetCPSR:
> > > > and used as:
> > > > Brendan
> > > SPONSORED LINKS
> > > Microcontrollers
l
> > > 	Microprocessor
m
> > > YAHOO! GROUPS LINKS
Terms of
2006-05-27 by David Hawkins
If you want an example of some simple code, and a better
understanding of what the tools are doing for you, take a
look at:
http://www.ovro.caltech.edu/~dwh/ucos/project_AR1803.pdf
http://www.ovro.caltech.edu/~dwh/ucos/gcc_and_ucosii.zip
The uCOS port has some assembler code, os_cpu_a.s, which
is an example of how to make assembler functions visible
to C code and vice versa.
Dave
2006-05-28 by Peter Jakacki
omkar vyas wrote:
> hi ,
> Peter, Thankx
I guess you have figured out by now that Yahoo strips attachments from
posts. Could I suggest that you download the files to some public
webspace and submit the link in your post so that anyone can view these
files and comment. If you do not have your own space perhaps you could
temporarily download to the groups file section and delete the material
after 30 days so as not to clutter the meager space that Yahoo provides.
*Peter*
2006-05-28 by dgaydou
I haven´t had fixed my problem with the linker, but i´ve found
helpfull those sites because i´m trying to port ucos_ii to LPC2114
and the examples from AR1830 work perfectly. That´s exactly what i
need to start my work. Thanks for your help. May be some day i can
find out where´s the problem with the linking of my files. I´ll tell
you... :)
Cheers
David
working,
> look at:
> Cheers,
> Dave
2006-05-29 by omkar vyas
ya thankx peter but fortunatly i could solve the problem but i will definatly find my own space n forward u the link!
 > hi ,
 > Peter, Thankx
 *Peter*
        SPONSORED LINKS
   YAHOO! GROUPS LINKS
Do you Yahoo!?
 Everyone is raving about the  all-new Yahoo! Mail Beta.
