Lpc2000
Libary problem with Hitop5 from Hitex
2006-05-31 by geri882
I have a problem with including the stdio.h into my project in
Hitop5 for programming a LPC controller.
Hitop5 is the programming IDE from Hitex and uses the GNU compiler.
I need the the libary because of the sprintf command.
The libary is included with:
#include <stdio.h>
and the syntax of the sprintf command is 100% correct.
So there must be a problem with the including or the use of libary
header files.
Here for example some warnings from the built process:
(C:\Programme\Hitex\GnuToolPackageArm\arm-hitex-elarm-hitex-elf-ld:
Warning: C:\Programme\Hitex\GnuToolPackageArm\arm-hitex-
elf\lib/libc.a(sprintf.o) does not support interworking,
whereas .\objects\2138LCD.elf does
arm-hitex-elf-ld: Warning: C:\Programme\Hitex\GnuToolPackageArm\arm-
hitex-elf\lib/libc.a(vfprintf.o) does not support interworking,
C:\Programme\Hitex\GnuToolPackageArm\arm-hitex-elf\lib/libc.a
(vfprintf.o)(.text+0xb54): In function `_vfprintf_r':
../../../../../../GccSources/newlib-
1.13.0/newlib/libc/stdio/vfprintf.c:821: undefined reference to
`__ltdf2'
(mprec.o)(.text+0xbdc): In function `_mprec_log10':
1.13.0/newlib/libc/stdlib/mprec.c:983: undefined reference to
`__muldf3'
There are a lot more similar warnings or errors like above.
Has anyone an idea or can help? Or is anyone working with Hitop 5
and doesn't have this problem with including libary files?
It would also be helpful,if there are functions which can change
integers or floats into char(in decimal, hex and binary syntax)
Thanks for helping
Bye Bye
Gerald
Re: [lpc2000] Libary problem with Hitop5 from Hitex
2006-06-01 by Tom Walsh
geri882 wrote:
>Hi,
>#include <stdio.h>
>header files.
>`__ltdf2'
>`__muldf3'
>Thanks for helping
>Bye Bye
>Gerald
strings libgcc.a | grep __muldf3
__muldf3
__muldf3
__muldf3
__muldf3
__muldf3
__muldf3
__muldf3
Hmm, looks like you have some problem finding libgcc.a to link
against?   Probably a poorly constructed link sequence when specifying
libs and their order of linking.
'ld' is a single pass linker, it is not a multi-pass linker as you may
be used to in the windows world.  Think of it as a 'link-ahead', you
have an object file with an unsatisifed reference, the linker will
resolve that reference in the subsequently named libs / object files.
Any previous mention of that name, prior to the reference, is ignored.
This allows you to override library references with your own wrapper
code, etc, etc.
TomW
>Yahoo! Groups Links
Re: Libary problem with Hitop5 from Hitex
2006-06-01 by geri882
--- In lpc2000@yahoogroups.com, Tom Walsh <tom@...> wrote:
> geri882 wrote:
> >Hi,
compiler.
> >#include <stdio.h>
libary
> >header files.
ld:
> >`__ltdf2'
> >`__muldf3'
> >Thanks for helping
> >Bye Bye
> >Gerald
> __muldf3
> __muldf3
> __muldf3
> __muldf3
> __muldf3
> __muldf3
> __muldf3
specifying
may
you
files.
ignored.
wrapper
> code, etc, etc.
> TomW
It's possible that, the linker makes a problem and can't include an
assembler libary. But the path in the startupcode generator for
assembler libarys ist right.
And I have no idea where it's possible to make those adjustments in
Hitop.
HAs anyone an idea whos also working with Hitop?
I have this problem, when the sprintf instruction is used. When
sprintf is commented out I have no problem.
So is the stdio.h libary only included if an istruction of the
libary is used?
Gerald
