Hello Bob,
As it can be seen from user manuals that are accompanying LPC2000
microcontrollers, port pins can be configured to perform one out of
up to four digital/analog functions, GPIO pin function being one of
them.
In case of the LPC2114/2124 part, the one you are working with, the
IOPIN register described in the "Table 68: GPIO Register Map"
("LPC2114/2124/2212/2214 User Manual", page 110, February 03, 2004
edition) refers to IOPIN as "GPIO Port Pin value register", and not
to the "Port Pin value
" in general. More detailed description of the
same register (page 111), starts with:
"This register provides the value of the GPIO pins
Therefore, IOPIN reflects any outside world influence on the GPIO
configured pins only! Monitoring of non-GPIO configured port pins
using IOPIN register will not be valid, since activities on non-GPIO
pins are not indicated in the IOPIN register.
Selection of a single function on a port pin completely excludes all
other functions otherwise available on the same pin.
The only partial exception to the above rule of exclusion is in the
case of inputs to the A/D converter. Regardless of the function that
is selected for the port pin that also hosts the A/D input, this A/D
input can be read at any time and variations of the voltage level on
this pin will be reflected in the A/D readings. However, valid analog
reading(s) can be obtained if and only if the function of an analog
input is selected. Only in this case proper interface circuit is
active in between the physical pin and the A/D module. In all other
cases, a part of digital logic necessary for the digital function to
be performed will be active, and will disrupt proper behavior of the
A/D.
This is the way all ports in Philips LPC2000 family of
microcontrollers are designed to operate.
Hope this clarifies the subject of GPIO pins.
Philips apps.
--- In lpc2000@yahoogroups.com, "bobbruce000" <bobbruce000@y...>
wrote:
> --- In lpc2000@yahoogroups.com, "Lee Studley" <indigo_red@q...>
wrote:Show quoted textHide quoted text
> > Hi Bob,
> > I wouldnt really say this is a hardware bug, but a documentation
> > bug.
> I guess that is one way to look at it. So let me rephrase my
> question:
> The LPC2106 docs contain a bug, when they state that the pins
> are readable even if an alternate funcion is enabled.
> The LPC2114 docs contain the same statement. But is this
> another "documentation bug", or does it accurately reflect
> what the hardware actually does?
> Happy now? ;-)
> > Can you switch to GPIO, then get the level, then back as needed?
> > Or will this cause a glitch.
> No. I cannot think of any way to do that reliably. There is always
> a chance of missing a transition.
> The only solution I can think of, is to dedicate additional pins,
> and have the signal go to a capture pin and also to a GPIO pin.
> Since I will have eight capture signals, that means I need to give
> up eight other pins, that I would rather use for other purposes.
> But I need to know before I etch a board, which is why I am asking.
> -bob
