Lpc2000
proble using MCB2100 with lpc 2129
2004-04-26 by tengbat1980
When I use the MCB2100,i found i cant make the Switch 2  working.
I couldn't find the memory address,and When I pressed Switch 2, any
change have not be found .
anybody can help me with that how to enable the swtich 2 ?
And any function do it?
Re: [lpc2000] proble using MCB2100 with lpc 2129
2004-04-26 by Michael Pont
Dear "tengbat",
I don't have a board or documents in front of me, and can't give you a precise answer, but this - from memory - may help.
One of the jumpers (the third one?) needs to be in place if you want to read the S2 settings.  There are no functions, etc, require (beyond your basic switch interface code).
Michael.
> From: "tengbat1980" <tengbat1980@...>
> Date: 2004/04/26 Mon AM 08:47:05 GMT
> To: lpc2000@yahoogroups.com
> Subject: [lpc2000] proble using MCB2100 with lpc 2129
 Michael J. Pont, PhD
 Embedded Systems Laboratory,
 University of Leicester
 http://www.le.ac.uk/eg/embedded
Re: proble using MCB2100 with lpc 2129
2004-04-26 by embeddedjanitor
--- In lpc2000@yahoogroups.com, "tengbat1980" <tengbat1980@y...>
Switch 2 is connected to P0.14, but you need to have the jumper J7 in
place for it to work.
Then, how do you want to access it?
If you want to use it as a GPIO, then you need to configure the GPIO
and pin matrix to enable this pin as a GPIO input. You can then
access it via the GPIO pins registers.
If you want to use this as EINT1, you will need to also set up the
interrupt controller.
2004-04-27 by tengbat1980
thanks and i have use some fuction to solve this proglem and enable
the switch2 interrupt.
  VICIntSelect=0x00008000;
  VICIntEnable=0x00008000;
  VICFIQStatus=0x00008000;
  PINSEL0=0x20000000;
But now when i entry interrupt,couldnt out,And I have not found the
return instruction.how i can solve this problem.
--- In lpc2000@yahoogroups.com, "embeddedjanitor" <manningc2@a...>
any
in
GPIO
2004-04-27 by embeddedjanitor
>   PINSEL0=0x20000000;
This depends on how you have written your interrupt handler. Is it in
C or assembler? gcc or ADS or what compiler? ....
I use gnu c compiler.And can't return the interrupt.Have any way to
solve it?thanks
enable
> >   PINSEL0=0x20000000;
in
Re: [lpc2000] Re: proble using MCB2100 with lpc 2129
2004-04-27 by Charles Manning
> solve it?thanks
Have a look at the BLINKEYIRQ.ZIP example in the download area of the Keil
website.  THis shows how you can write a C function with an interrupt
attribute. This will apply the appropriate interrupt wrappers.
I personally prefer to do my own interrupt wrappers in assembler, which might
themselves call C functions. THis allows more flexibility and control.
-- Charles
> enable
> > >   PINSEL0=0x20000000;
> the
> in
Thanks,I would try it.
best regards
--- In lpc2000@yahoogroups.com, Charles Manning <manningc2@a...>
to
> > solve it?thanks
the Keil
interrupt
which might
control.
> -- Charles
<manningc2@a...>
<tengbat1980@y...>
> > enable
> > > >   PINSEL0=0x20000000;
found
> > the
Is it
> > in
> > Yahoo! Groups Links
