Lpc2000
lpc2292 external sram
2004-07-14 by douglasbolton
I'm putting a 128k*16 external sram onto an lpc2292. I've set the
external memory controller for this bank to be 16 bits wide. Does the
compiler need to know about the width of the external ram bus or does
the external memory controller look after this ?
I'm using the IAR compiler but am interested in all compiler
situations
Doug
Re: lpc2292 external sram
2004-07-14 by philips_apps
Doug,
The compiler does not need to know about the width of the external
RAM. It's all taken care by the EMC provided that the bank
configuration registers are intialized correctly.
If you are planning to execute code from the external 16 bit bank
then the THUMB code will give you better execution performance than
the ARM code. Each ARM instruction will require 2 accesses to the 16
bit bank where as Thumb instruction will require only one access.
Philips Apps.
does
> situations
> Doug
