Lpc2000
Trouble with P0.2 as GPIO
2004-07-27 by rkd0930home
Hi All,
I am having difficulty with controlling pin P0.2 as a GPIO output
signal. I am successfully controlling several other pins on my board.
I have set bit 4 and 5 of PINSEL0 to zero. I have set bit 2 of IO0DIR
to 1 and I have set bit 2 of IO0SET to 1. P0.2 stays at zero. I have
used the same procedure on other pins with success. Is there
something I am missing?
Bob Davis
Re: Trouble with P0.2 as GPIO
--- In lpc2000@yahoogroups.com, "rkd0930home" <rkd0930@c...> wrote:
> Hi All,
board.
IO0DIR
have
> Thanks,
> Bob Davis
I just found a previous email on the issue and I now know that this
pin is an open collector output. Thanks anyway.
Bob Davis
RE: [lpc2000] Trouble with P0.2 as GPIO
2004-07-27 by Curt Powell
Read the I2C documentation in the user manual.  P0.02 and P0.03 are open
drain pins.  You need a pull-up.  (Been there, done that, got the
T-shirt!)
Sent: Tuesday, July 27, 2004 6:46 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Trouble with P0.2 as GPIO
Hi All,
Bob Davis
Yahoo! Groups Links
Re: [lpc2000] Trouble with P0.2 as GPIO
2004-07-27 by Robert Adsett
That's one of the I2C pins, do you have a pull-up on it?
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
2004-07-27 by Leighton Rowe
Which lpc eval board u are u using? I wouldn't mind viewing the
schematic to see how P0.2's connected to everything.
It would be very wierd if P0.2 stays low when set, even if the pin's
not connected to any circuit.
> Hi All,
board.
IO0DIR
have
> Thanks,
> Bob Davis
