Philips download utility in compare
2004-07-27 by Robert Adsett
I was just trying to help track down some odd compare behaviour someone had
seen using my serial ISP adaptor and I believe we've run into a bug in the
latest version of the Philips ISP utility.
It fails if a compare is asked for. The version that fails is the latest
2.2.0. Version 2.0.3 works fine (the same micro with the same hex compares
fine using 2.0.3 and not with 2.2.0). Oh and the program does work.
I've tried this with both the automatic control of reset and mode pins and
using manual control with no difference.
Has anyone else run into this?
I've also posted to Philips forum to see if they have any thoughts.
" 'Freedom' has no meaning of itself. There are always restrictions,
be they legal, genetic, or physical. If you don't believe me, try to
chew a radio signal. "
Kelvin Throop, III
