Lpc2000
Problem configuring external interrupts...
2004-08-04 by Musharraf Hanif
I am trying to setup my LPC2129 (MCB2100) to respond
to external interrupts. I am using the following
initialization sequence (For the interrupt):
VICVectAddr3 = <whatever>;
VICVectCntl3 = 0x2F;
//Change mode of the interrupt pin
PIN_Set_Mode(014,1,0); //P0.14 with mode bits 10
EXTMODE |= 0x02; //Use Edge triggered
EXTWAKE |= 0x02; //Interrupt wake the processor
EXTINT |= 0x02; //Clear the EINT1 interrupt source
VICIntEnable |= 0x008000; //Enable EINT1
while(1)
  Function_to_toggle_a_GPIO_pin();
  Delay();
In the ISR:
EXTINT |= 0x02; //clear the source of the interrupt
Counter_G++;
Display_value_of_Counter();
Now for the problems:
With this initialization sequence, the initialization
stops when changing to edge triggered mode. By
removing this and the following line (Wake up
related), the initialization runs all the way through.
However, in this mode, it is in level triggered mode.
triggering the interrupt causes the counter to be
updated.... however, this happens only once... while
the back ground task continues to run, showing that
the ISR is exited....
I should also mention that incase of an undefined
interrupt, the system goes into an infinite loop...
could this and enabling the VIC channel before setting
up the interrupt be the cause of the problem?
Can anyone help me in solving this problem?
Musharraf Hanif
Do you Yahoo!?
Read only the mail you want - Yahoo! Mail SpamGuard.
http://promotions.yahoo.com/new_mail
Re: Problem configuring external interrupts...
2004-08-05 by douglasbolton
--- In lpc2000@yahoogroups.com, Musharraf Hanif
<musharraf_hanif@y...> wrote:
> Hi,
> while(1)
>   Delay();
> In the ISR:
> Counter_G++;
> Regards,
> Musharraf Hanif
> Do you Yahoo!?
Take a look at the errata data sheet . There are some known problems
and work arounds with external interrupts.
Doug
Test
2004-08-05 by FabioDB
test
 Email.it, the professional e-mail, gratis per te: http://www.email.it/f
 Sponsor:
 Realizza regali originali con le tue foto/immagini/scritte!
* Stelle & Strisce stampa quello che vuoi TU .... dove Vuoi Tu!!
 Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=2118&d=5-8
2004-08-08 by Musharraf Ahmed Hanif
Thanks for that. The controller now does not hangup during
initialization, however, it still processes the interrupt only once.
i.e. after the 1st interrupt, all other interrupts are ignored. I am
clearing the EINTx flag by writing a 1 to that bit.
Has anyone managed to use external interrupts without such problems?
Musharraf Hanif
> > Hi,
> > while(1)
> >   Delay();
> > In the ISR:
> > Counter_G++;
> > Regards,
> > Musharraf Hanif
> > Do you Yahoo!?
problems
> Doug
2004-08-08 by haack0815
Hi Musharraf,
at the end of your ISR you must reset the VICVectAddr to 0.
Andreas
--- In lpc2000@yahoogroups.com, "Musharraf Ahmed Hanif"
> Regards,
> Musharraf Hanif
> > > Hi,
> > > while(1)
> > >   Delay();
> > > In the ISR:
> > > Counter_G++;
> > > Regards,
> > > Musharraf Hanif
> > > Do you Yahoo!?
> problems
> > Doug
Re: [lpc2000] Re: Problem configuring external interrupts...
2004-08-09 by Robert Adsett
Actually any value will do.  The following works just fine
         ldr     r0, =VICVectAddrRead    /*  Let VIC know we are done.   */
         str     r0,[r0]
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
