Lpc2000
Flash utility won't connect when using a 3.6864MHz crystal
2004-08-11 by rattencremesuppe
I'm using a TinyARM eval board which worked fine with a 10MHz crystal.
Then we replaced it with a 3.6864MHz crystal and now Philips Flash
utility says that it can't connect to the test board.
When measuring the UART TX pin with a scope, there is some traffic
when trying to connect. But Philips flash utility somehow doesn't
recognize.
My flash utility settings are:
Device: LPC2106
XTAL Freq. (kHz): 3686
Use Baud Rate: (have tried all available baudrates with no success)
Time-Out (sec): 10
"Use DTR/RTS" is unchecked (there are only Rx & Tx connected)
3.6864 MHz seems to be a fairly common clock rate and there should be
some standard baudrates available (divisor 32 for 115.2 kBaud, for
example)
Is anyone out there using LPC2106 w/ 3.6864 crystal and knows how to
use the flash utility for this setup? If not, are there any
alternatives to using the philips flash utility?
Obviously, I can't use a own bootloader because there is no
possibility to initially put it on the chip, when the flash utility
doesn't work.
Best regards,
Patrick
Re: [lpc2000] Flash utility won't connect when using a 3.6864MHz crystal
2004-08-11 by Micron Engineering
You have to use a crystal with a frequency higher then 10MHz or you
can't use boot mode to program flash and so download your program. This
is written on Philips user manual.
Best regards,
Massimo Manca, Micron Engineering
rattencremesuppe wrote:
> Hi,
> recognize.
> Device: LPC2106
> Time-Out (sec): 10
> example)
> doesn't work.
> Best regards,
> Patrick
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=1297i6bo9/M=298184.5285298.6392945.3001176/D=groups/S=1706554205:HM/EXP=1092321065/A=2164331/R=0/SIG=11eaelai9/*http://www.netflix.com/Default?mqso=60183351>
>     * To visit your group on the web, go to:
>       http://groups.yahoo.com/group/lpc2000/
>     * To unsubscribe from this group, send an email to:
>       lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2004-08-11 by Robert Adsett
My data sheet shows the minimum crystal frequency as 10MHz.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: Flash utility won't connect when using a 3.6864MHz crystal
2004-08-12 by Frank Sergeant
"rattencremesuppe" <tricknology@...> writes:
Everyone agrees, apparently, that we need at least a 10 MHz crystal.
That's too bad.
I've had in mind the idea of "de-tuning" the LPC210x to make it somewhat
of a PIC or MSP430 replacement.  I find the ARM much more pleasant to
program than the PIC and it would be nice to stick with a single CPU and
instruction set etc. etc. ("one size fits all").  Of course, the power
supply and sometimes the clock will still be more complicated than with
the PIC.
I'm using Martin Maurer's lpc21isp program from
   http://www.engelschall.com/~martin/lpc21xx/isp/index.html
as the bootloader running under Linux.  Here is the command I use with
my Olimex LPC2106 board with a 14.7456 MHz crystal:
     lpc21isp -bin combo.bin /dev/ttyS0 115200 14746
So, your crystal at 3.6864 MHz is exactly one fourth that speed.  I
wonder if you could use either the Philips bootloader or the Maurer
bootloader and /say/ the crystal speed is 14746 even though it is only a
quarter of that.  The bootloader (at least Maurer's) might not actually
set the serial port speed, I'm not sure.  In which case you might really
set the serial port speed to 9600 but say the baud rate is 38400, e.g.
     lpc21isp -bin combo.bin /dev/ttyS0 38400 14746
There might be some way to trick the bootloader and the chip into
programming the Flash.  Perhaps the Flash time periods would then be
off.  It might still work.
I think the source is available for Maurer's bootloader, so if it does
set the serial speed, we might be able to change it to set it to one
quarter of what it will tell the LPC chip.
I hope you will experiment further and let me know how it all works out.
Another possibility might be to have two clock sources.  A fast one used
just to do the initial programming of a custom bootloader (or perhaps
used everytime you program the Flash) and a slow one for normal use to
conserve power.  Just a thought.
Frank
Re: [lpc2000] Re: Flash utility won't connect when using a 3.6864MHz crystal
2004-08-12 by Robert Adsett
I think you misunderstood.  The 10MHz limit is listed as the minimum
operating frequency (for all conditions) not a minimum programming
frequency.  I'd expect most chips would work at least a little below that
but more than a factor of 2 is probably wishful thinking.
There are other small ARMs that will work with lower frequency inputs (The
AD parts come to mind).
Robert
                         Kelvin Throop, III
2004-08-13 by philips_apps
Clarification for possible clocks into the LPC2000 family, applies to
all devices.
The input to the crystal oscillator can be any frequency from 1-30 MHz.
The input from the crystal oscillator into the PLL has to be in the
range of 10-15 MHz (hence the spec).
The ISP program needs the 10 MHz to function properly  but a
modification of the other source file, refered to as Maurer's code
might make it work.
So to exclude any doubts, it is possible to run the LPC2xxx devices at
3.6864 MHz but you can not use the PLL!
Our recommendation for frequencies outside the "mainstream
applications", use a JTAG debugger  that supports programming such as
Ashling, ARM, Nohau, Hitex, Keil, IAR. Hope I did not forget anyone.
Will be more clear in future User's Manuals, my apologies, Robert
that
inputs (The
> Robert
>                          Kelvin Throop, III
2004-08-14 by Robert Adsett
>all devices.
>might make it work.
Just to make sure all the proper places get noted.  I got the 10MHz-25MHz
oscillator frequency range from the data sheet not the user manual.
Robert
                         Kelvin Throop, III
