Lpc2000
IAR, JLINK and PLL problems
2004-09-04 by itsjustimpossible
Hi
We are using the IAR workbench and Jlink to develop code for the
LPC2129. I must use the PLL and debug from FLASH as my timing is
criticle but the use of the PLL is preventing the Jlink connecting.
The only way around this is to use the Philips Flash utility to
erase the device each time before I start the debugger.
On the development board this is a pain, but I would prefer our
target board not to have a serial port if possible.
Firstly, has anyone managed to get around this problem? (The recent
Jlink DLL patch has not helped.)
Secondly, has anyone used an alternative debugger with IAR that does
not have this problem?
Any comments would be greatly appreciated.
best regards
Simon
Re: IAR, JLINK and PLL problems
2004-09-05 by douglasbolton
--- In lpc2000@yahoogroups.com, "itsjustimpossible" <simonjh@b...>
wrote:
> Hi
does
> best regards
> Simon
We had the same problem. Once you have programmed the flash with the
pll enabled the processor is history as far as the debugger is
concerned until you scrub the flash.
I found jlink will work ok with pll running if you set the following
in the jlink menu of the debugger.
1. tick philips lpc download button
2. tick reset aserts hardware reset pin
3. although this is not the case set the cclk to whatever you are
running the cpu clock
we have a 10mhz crystal pumped up to 60 mhz by the pll. In theory we
should set the cclk setting to 10000 in the jlink menu. This doesn't
work. If we set it to 60000 we have never had a problem!!!!
regards Doug
2004-09-08 by itsjustimpossible
Hi Doug
Thanks for the info, and it has helped in some circumstances but I
have to manually reset the board before I try to enter the debugger.
I am now wondering if the board is resetting properly. The Keil
evaluation board we are testing with has no reset IC, just an RC
network.
Are you using a reset IC on your target board?
cheers
Simon
> wrote:
> > Hi
connecting.
<snip>
following
we
doesn't
> regards Doug
2004-09-08 by douglasbolton
wrote:
> Hi Doug
debugger.
> network.
> cheers
> Simon
<simonjh@b...>
> > wrote:
> > > Hi
is
> connecting.
> <snip>
> the
> following
> we
> doesn't
> > regards Doug
Yes we had to put a reset device in, we use a max809 (140mS delay)
and haven't had any problems. With an RC network we had trouble with
the debugger and actual boot ups of the board in standalone.
2004-09-10 by itsjustimpossible
with
Great, I will give it a try.
Thanks
Simon
2004-09-10 by Richard
Reset duration needs to be 10ms at power-up and 300ns thereafter.  I
have seen problems with boards where the RC reset circuit provided a
reset pulse on power-up which was too short.
Rich
<simonjh@b...>
delay)
> with
> Thanks
> Simon
