Lpc2000
Using External AD Converters
2004-09-15 by Leighton Rowe
Has anyone used lpc's to operate AD7677s (using lpc's) before?
- 16-bit True differential input (-2.5V to +2.5V input range)
- 1 MSPS conversion rate
Basically the ADC's set up such that:
3V                                ---> Vref pin
Analog input (always +ve Voltage) ---> Vin+ pin
-90mV reference                   ---> Vin- pin
I have a little problem with the readings that I'm currently getting:
Input = 0V (GND)
The lpc reads 0x8000 from the converter. I assume this is the mid-
point.
Input = 330mV
Reading: 0x8000....strange
Input = 660mV
Reading = 0x8050...stranger
Input = 1.32V
Reading = 0xB8F0. OK (the calculation's legit)
The A/D seems to be reading correct but only for a specific range.
1.32V and above will read correctly. But For some reason the lower
voltages aren't coming out right. Any ideas? Could the hardware
setup for Vin+ and Vin- be causing this problem?
thanks,
Leighton
Re: [lpc2000] Using External AD Converters
2004-09-16 by Kerem Or
It appears there is a common mode voltage problem. Check if there is a
current return path between AIN-/AIN+ and AGND. What you observed can happen
if the signal source is floating with respect to AGND. As you have noted the
AD accepts -2.5V to 2.5V. But since the part is not bipolar, the applied
input signal must not be above VCC or below ground with respect to AGND.
i.e, -2.5V actually means 0V connected to AIN+ and 2.5V connected to AIN-.
It is not -2.5V with respect to AGND.
Just make sure voltage on any of the differential pins is in between the
part's common mode range.
Kerem
To: <lpc2000@yahoogroups.com>
Sent: Thursday, September 16, 2004 12:08 AM
Subject: [lpc2000] Using External AD Converters
> 3V                                ---> Vref pin
> Input = 0V (GND)
> point.
> Input = 330mV
> Input = 660mV
> Input = 1.32V
> thanks,
> Leighton
Re: Using External AD Converters
2004-09-16 by Leighton Rowe
The analog inputs and references look stable to me. No floating
pins. I've made the Vin- input closer to ground:
Analog input (always +ve)---> Vin+
0V                       ---> Vin-
3V                       ---> Vref
5V                       ---> AVDD/DVDD
...but the same readings are still coming out. Maybe it's because
I'm using a "true differential" ADC. I heard the setup's different
compared to pseudo differential which I'm more accustomed to using.
is a
can happen
noted the
applied
AGND.
to AIN-.
between the
> Kerem
2004-09-17 by ebland_us
It sounds like your inputs aren't truly differential.  You've
referenced the V- input as a reference 90mV.... which makes it a
unipolar signal, essentially.  A differential input won't have this
type of reference as Karem mentioned below.   You could force the
inputs into the 0-5V range by using a 2.5V ADC reference.  You can
still you a differential input but will then want to make the input
amplifier's common mode reference at 2.5V... or half of the reference
voltage so that it's centered in the range.
Edwin
--- In lpc2000@yahoogroups.com, "Leighton Rowe" <leightonsrowe@y...>
> 0V                       ---> Vin-
> 3V                       ---> Vref
> 5V                       ---> AVDD/DVDD
> is a
> can happen
have
> noted the
> applied
to
> AGND.
> to AIN-.
> between the
> > Kerem
2004-09-17 by Leighton Rowe
Thanks
this
input
reference
> Edwin
> > 0V                       ---> Vin-
> > 3V                       ---> Vref
> > 5V                       ---> AVDD/DVDD
because
different
using.
there
> > is a
observed
> > can happen
> have
> > noted the
> > applied
respect
> to
> > AGND.
connected
> > to AIN-.
> > between the
> > > Kerem
