Lpc2000
Don't understand I2C addresses on Ashling LPC2106 eval board
2004-10-05 by brust@symyx.com
I'm trying to implement I2C communication with my Ashling LPC2106
eval board, and to get started, I've been reviewing the Ashling Full
example.  That project communicates with two I2C devices on the eval
board, a 7-segment LED and a DIP switch.  The documentation
indicates the 7-segment display is at I2C address 0x01 and the DIP
is at I2C address 0x00.  However in the code, writes to the 7-
segment LED use an address data byte of 0x42, which I interpret as a
slave address of 0x21 and a direction bit of 0 (for writing).
Similarly, when reading the DIP switch, the address data byte is
0x41, or a slave address of 0x20 and a direction bit of 1 (for
reading).  Is this an error in the eval kit documenation, or must
the high nibble in the address be set to 0x2 for some reason?
Thanks!
Bill
Re: Don't understand I2C addresses on Ashling LPC2106 eval board
2004-10-06 by embeddedjanitor
Full
eval
a
What you see is correct.
The address allocation is governed by a specification and an I2C
committee. The address is typically made up of two parts: a class
address and a device address. The "class address" is defined in the
silicon and the "device selector" is typically the address that you
can manipulate via address selection pins. The least significant bit
is the r/w selector.
For example:
The IO devices you have area all 0010xxxy
Microchip (and perhaps other) SEEPROMs are all 1010xxxy
This strategy allows you to determine what type of devices are
attached by the addresses. It also allows for easier device selection
pinning and reduction of conflicts between devices.
RE: [lpc2000] Don't understand I2C addresses on Ashling LPC2106 eval board
2004-10-06 by Hugh O'Keeffe
Hi Bill,
Answer below; this is in HTML format, hence, Yahoo may munch it. Contact me
directly and I'll send you a Word or PDF version
Hugh @  <http://www.ashling.com/support/lpc2000/>
The I2C device used on the LPC2xxx is a PCF8574T and the Address decoding
for this device is as below:
There are two PCF8574T devices on the LPC2xxx these are identified from each
other using the A (2..0) Bits.
With the Least significant bit of the register determining whether it is a
read or a write. Therefore:
Address of 0x42 writes to seven-segment display.
Address of 0x41 reads from the DIPswitches and the Test points (TP1, TP2,
TP3 and TP4).
Address of 0x40 writes to the Test points (TP1, TP2, TP3 and TP4).
Sent: 06 October 2004 00:34
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Don't understand I2C addresses on Ashling LPC2106 eval
board
Thanks!
Bill
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129m682pf/M=295196.4901138.6071305.3001176/D=gr
oups/S=1706554205:HM/EXP=1097105665/A=2128215/R=0/SIG=10se96mf6/*http://comp
anion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=
:HM/A=2128215/rand=488420195>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
