LPC Reset..
2004-10-07 by bty639886
Is there any way to reset the processor from within the firmware? I am currently using the Watchdog feature, and I know if I stop toggling the watchdog then my processor will time out and reset. However, I need to be able to do different things depending on the 'cause' of the reset... ie if its a watchdog timeout that caused reset I need to do X,Y,Z before normal operation but if its a software triggered reset (eg after I have updated a parameter or something in flash) then I only want it to do Y,Z Obviously I could use some external hardware, however is there any way to do it in software???? any help is appreciated! cheers, pete
