3rd serial port
2004-10-18 by ggindele
I'll need a 3rd serial port to debug the application, just to dump out logs. Maybe SPI? But then I would need a SPI-RS232 converter. Any recommendation? Gabe
2004-10-18 by Lasse Madsen
Hi Gabe Maxim makes SPI=>RS232 converters by as far as i remember they are pretty expensive... Best regards Lasse Madsen
-----Original Message----- From: ggindele [mailto:ggindele@...] Sent: 18. oktober 2004 14:24 To: lpc2000@yahoogroups.com Subject: [lpc2000] 3rd serial port I'll need a 3rd serial port to debug the application, just to dump out logs. Maybe SPI? But then I would need a SPI-RS232 converter. Any recommendation? Gabe Yahoo! Groups Links
2004-10-18 by Leon Heller
>From: "Lasse Madsen" <lasse.madsen@...> >Reply-To: lpc2000@yahoogroups.com >To: <lpc2000@yahoogroups.com> >Subject: RE: [lpc2000] 3rd serial port >Date: Mon, 18 Oct 2004 14:27:07 +0200 > > >Hi Gabe > >Maxim makes SPI=>RS232 converters by as far as i remember they are >pretty expensive... I've used them, and they are very good, but expensive. Another option would be to use a small '2313 AVR (or a PIC) as a software UART connected to the LPC2000 via SPI. I did this once for a comms hub, with software SPI running on three '2313s, connected to a mid-range PIC, and it worked very well. Hardware cost will be lower, but software will have to be written. It was a cheaper solution in our case, for quantity production. Leon
2004-10-18 by Pete
alternatively if you are using an LPC with the peripheral bus you can easily add a UART chip (Philips have a large range) and add any number of UART ports. Relatively cheaply too. Again, drivers need writing but very simple to do so... I believe they have singles,duals,quads and octals available... rgds pete --- In lpc2000@yahoogroups.com, "Leon Heller" <leon_heller@h...> wrote: > > > > >From: "Lasse Madsen" <lasse.madsen@e...> > >Reply-To: lpc2000@yahoogroups.com > >To: <lpc2000@yahoogroups.com> > >Subject: RE: [lpc2000] 3rd serial port > >Date: Mon, 18 Oct 2004 14:27:07 +0200 > > > > > >Hi Gabe > > > >Maxim makes SPI=>RS232 converters by as far as i remember they are > >pretty expensive... > > I've used them, and they are very good, but expensive. Another option would > be to use a small '2313 AVR (or a PIC) as a software UART connected to the > LPC2000 via SPI. I did this once for a comms hub, with software SPI running > on three '2313s, connected to a mid-range PIC, and it worked very well. > Hardware cost will be lower, but software will have to be written. It was a
> cheaper solution in our case, for quantity production. > > Leon
2004-10-18 by David Kay
The Philips LPC900 series of micros have on-board UARTS down to 8 pin packages and are very good value for money - starting at a US$1 or so. The on-board RC oscillators of these devices are now factory trimmed to allow them to be accurately used for UART comm's - no xtal/ceramic osc required - further keeping the costs down. Philips LPC900 site - http://tinyurl.com/3ntch You could use the larger pin devices on a parallel bus or go for one of the smaller packages and use I2C or SPI comm's. The software required to turn one of these micro's into an addressable UART is very small - a few hundred bytes. You can even pick a small development board direct from the Philips site - MCB900 - for US$59, more than powerful enough to develop this type of code on. Philips has a huge range of single/dual/quad/octal UARTS but the costs don't stack up against these smaller micros. Even the devices with FIFO's could be successfully emulated using the RAM in the micro. David Kay Field Application Engineer - New Zealand local focus_global reach - That's adilam !
-----Original Message----- From: Leon Heller [mailto:leon_heller@...] Sent: Tuesday, 19 October 2004 1:55 a.m. To: lpc2000@yahoogroups.com Subject: RE: [lpc2000] 3rd serial port >From: "Lasse Madsen" <lasse.madsen@...> >Reply-To: lpc2000@yahoogroups.com >To: <lpc2000@yahoogroups.com> >Subject: RE: [lpc2000] 3rd serial port >Date: Mon, 18 Oct 2004 14:27:07 +0200 > > >Hi Gabe > >Maxim makes SPI=>RS232 converters by as far as i remember they are >pretty expensive... I've used them, and they are very good, but expensive. Another option would be to use a small '2313 AVR (or a PIC) as a software UART connected to the LPC2000 via SPI. I did this once for a comms hub, with software SPI running on three '2313s, connected to a mid-range PIC, and it worked very well. Hardware cost will be lower, but software will have to be written. It was a cheaper solution in our case, for quantity production. Leon Yahoo! Groups Links
2004-10-18 by Peter Jakacki
Since your traffic is mostly one way it would be very easy to implement a bit-banged serial I/O. This can driven off a timer interrupt or if it doesn't matter too much then a simple polled routine. If you only needed to transmit then you can select a very high baud rate which would then take up less CPU cycles. The timer interrupt per bit is another viable alternative which is very easy to implement also. Bit-banged serial I/O typically only needs a 100 bytes or so of code space to implement. I would certainly steer clear of hanging dedicated UARTs whether parallel or SPI off the micro as they do tend to be rather expensive. Why it's cheaper to use a micro as a Uart but you still need code to talk to it anyway. EXTRA SERIAL CHANNEL SELECTION GUIDE ------------------------------------------ EXTERNAL UART + CODE + INTERFACE = $$$ EXTERNAL SPI UART + CODE = $$$ EXTERNAL MICRO + CODE = $ BIT-BANGED I/O + CODE = free my2cents Peter Jakacki ggindele wrote:
>I'll need a 3rd serial port to debug the application, just to dump out >logs. Maybe SPI? But then I would need a SPI-RS232 converter. >Any recommendation? > >Gabe > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > >
David,
These 8-pin LPC900s look great but how do you get them? I checked a
while back and samples were not available. I could buy a full reel if I
wanted to sample them though ;)
Peter Jakacki
David Kay wrote:>The Philips LPC900 series of micros have on-board UARTS down to 8 pin >packages and are very good value for money - starting at a US$1 or so. >The on-board RC oscillators of these devices are now factory trimmed to >allow them to be accurately used for UART comm's - no xtal/ceramic osc >required - further keeping the costs down. > >Philips LPC900 site - http://tinyurl.com/3ntch > > ><snip> > >
2004-10-19 by David Kay
Hi Peter, Your local Philips disti should be able to order samples for you. Philips have greatly streamlined there samples system in the last few years - you should be able to get 5pcs free of charge in a week or two. If you are in Aus/NZ I could do it for you? Just drop me an email to:- david (dot) kay (at) adilam (dot) com (dot) au With your details, address etc and we'll see what we can do. David Kay Field Application Engineer - New Zealand local focus_global reach - That's adilam !
Sent: Tuesday, 19 October 2004 12:51 p.m.
Subject: Re: [lpc2000] 3rd serial port
David,
Peter Jakacki
><snip>
Yahoo! Groups Links2004-10-19 by Robert Adsett
That does make the assumption that pins and code are free and that the CPU
isn't already occupied with other time critical functions. ;).
I don't know about the original poster but I place some value on my
time. For a strictly debug it may well be cheaper to simple hang some HW
off a header to SPI or I2C even if the chips are more expensive than a 16550.
Robert
" 'Freedom' has no meaning of itself. There are always restrictions,
be they legal, genetic, or physical. If you don't believe me, try to
chew a radio signal. "
Kelvin Throop, III2004-10-19 by Paul
If anyone from Philips is listening, I can't tell you how many times I've had a situation like this.... and the solution was to order parts from Digikey at 4:30 pm for UPS RED delivery the next morning. I'm sure there's a lot of issues franchising with digikey, but consider that almost all Atmel AVR-tiny and Microchip PIC chips are available tomorrow morning. That's faster than even finding out IF a Philips LPC sample might show up in a week or two. Paul > Philips have greatly streamlined there samples system in the last few > years - you should be able to get 5pcs free of charge in a week or two.
2004-10-19 by Peter Jakacki
Hi Rob, Since I'm still awake at this time of the night I'll answer quikly. The costs are only relative, so the bit-banged I/O is comparatively "free" I guess as compared to "$$$". A bit-banged transmit routine is about as primitive as you can get and most embedded programmers can whip up one in a very short space of time (gimme 15 mins or less). Compare that with interfacing a UART and getting it running right, I can absolutely guarantee that the bit-banged transmit is the cleanest, most simple, and cheapest option available. Hell, over short distances you can even run the transmit output directly at logic levels into a PC without anything more than maybe a current-limit resistor. I've never seen this not work or cause problems, and since this is simply for debugging then there are no compliance issues to worry about. my2cents worth of I/O Peter Jakacki Robert Adsett wrote:
>At 09:30 AM 10/19/04 +1000, you wrote: > > >>EXTRA SERIAL CHANNEL SELECTION GUIDE >>------------------------------------------ >>EXTERNAL UART + CODE + INTERFACE = $$$ >>EXTERNAL SPI UART + CODE = $$$ >>EXTERNAL MICRO + CODE = $ >>BIT-BANGED I/O + CODE = free >> >> > >That does make the assumption that pins and code are free and that the CPU >isn't already occupied with other time critical functions. ;). > >I don't know about the original poster but I place some value on my >time. For a strictly debug it may well be cheaper to simple hang some HW >off a header to SPI or I2C even if the chips are more expensive than a 16550. > >Robert > >
2004-10-19 by R M
I hate to respond with a 'me too' post, yet I second this motion. My company routinely purchases parts from DigiKey, with delivery to our door in one or two days (and we are in Canada). As a result I can get access to many parts very quickly. However, to get a few LPC samples, I have to talk to my Philips rep (Arrow), who has to talk to Philips, which can take over a week. And then if I want to purchase trays of parts, it takes a couple of weeks for Arrow to deal with our purchasing group, if they have stock. DigiKey takes a day or two, no matter the quantity. So Philips, if you are listening, please get your very wonderful LPC line on DigiKey's shelves. I know Atmel will have their new ARM7 line available at DigiKey, so should you. - Rod --- In lpc2000@yahoogroups.com, "Paul" <Paul@P...> wrote: > > If anyone from Philips is listening, I can't tell you how many times > I've had a situation like this.... and the solution was to order > parts from Digikey at 4:30 pm for UPS RED delivery the next morning. > > I'm sure there's a lot of issues franchising with digikey, but > consider that almost all Atmel AVR-tiny and Microchip PIC chips are > available tomorrow morning. That's faster than even finding out > IF a Philips LPC sample might show up in a week or two. > > > Paul > > > > > Philips have greatly streamlined there samples system in the last few > > years - you should be able to get 5pcs free of charge in a week or two.
2004-10-22 by rkdwork
--- In lpc2000@yahoogroups.com, "ggindele" <ggindele@y...> wrote: > > I'll need a 3rd serial port to debug the application, just to dump out > logs. Maybe SPI? But then I would need a SPI-RS232 converter. > Any recommendation? > > Gabe I am using an Aardvark SPI to USB converter for a debug messaging capability with an LPC2114. I have developed a device with a USB 2.0 interface and I needed a way to monitor the USB interrupt activity in real time to get through USB enumeration and configuration. My boss did not want to add a UART that would not be used in the final system. The Aardvark connects to the LPC2114 with no additional chips. The Aardvark comes with an ActiveX interface and a DLL. I wrote a VB application that displays the activity messages and stores them to a data file for subsequent review. This has allowed me to develop the USB interface without a USB protocol analyzer (very expensive). The Aardvark was developed by Total Phase (www.totalphase.com) Bob Davis
2004-10-23 by philips_apps
OK, let me have a shot at this one. To do business with Digikey takes 2 participants, Philips and Digikey. We, the apps guys asked for this coverage many times because we are aware how difficult it is to get small quantities :-( Unfortunately this is way outside our reach and there seem to be some differences between the responsible people at both ends. Everybody who would like to buy LPC2000 devices as well as LPC900 devices from Digikey could do us a great favor by asking Digikey as well as your local Philips representative if you know him/her why Digikey does not sell Philips devices. So, not only do I understand your frust, I share it. Let's keep pushing and pulling at both ends and hope that you can by and we can sell quantities of 1 through channels like Digikey. We will get there, hopefully rather sooner than later. Best regards, Robert --- In lpc2000@yahoogroups.com, "R M" <rodlist@r...> wrote: > > I hate to respond with a 'me too' post, yet I second this motion. > > My company routinely purchases parts from DigiKey, with delivery to > our door in one or two days (and we are in Canada). As a result I can > get access to many parts very quickly. > > However, to get a few LPC samples, I have to talk to my Philips rep > (Arrow), who has to talk to Philips, which can take over a week. > > And then if I want to purchase trays of parts, it takes a couple of > weeks for Arrow to deal with our purchasing group, if they have stock. > DigiKey takes a day or two, no matter the quantity. > > So Philips, if you are listening, please get your very wonderful LPC > line on DigiKey's shelves. I know Atmel will have their new ARM7 line > available at DigiKey, so should you. > > - Rod > > --- In lpc2000@yahoogroups.com, "Paul" <Paul@P...> wrote: > > > > If anyone from Philips is listening, I can't tell you how many times > > I've had a situation like this.... and the solution was to order > > parts from Digikey at 4:30 pm for UPS RED delivery the next morning. > > > > I'm sure there's a lot of issues franchising with digikey, but > > consider that almost all Atmel AVR-tiny and Microchip PIC chips are > > available tomorrow morning. That's faster than even finding out > > IF a Philips LPC sample might show up in a week or two. > > > > > > Paul > > > > > > > > > Philips have greatly streamlined there samples system in the last few > > > years - you should be able to get 5pcs free of charge in a week or > two.
2004-10-23 by Alex Gibson
philips_apps wrote: > > OK, > > let me have a shot at this one. To do business with Digikey takes 2 > participants, Philips and Digikey. We, the apps guys asked for this > coverage many times because we are aware how difficult it is to get > small quantities :-( Unfortunately this is way outside our reach and > there seem to be some differences between the responsible people at > both ends. > > Everybody who would like to buy LPC2000 devices as well as LPC900 > devices from Digikey could do us a great favor by asking Digikey as > well as your local Philips representative if you know him/her why > Digikey does not sell Philips devices. > > So, not only do I understand your frust, I share it. > > Let's keep pushing and pulling at both ends and hope that you can by > and we can sell quantities of 1 through channels like Digikey. > > We will get there, hopefully rather sooner than later. > > Best regards, Robert For those in Australia , Adilam Electronics www.adilam.com.au sells small quantities and Joseph Goldberg one of their Field Engineers is of great help. He reads this group as well. From an email I recieved recently they currently have stock of lpc2104 lpc2106 lpc2124 lpc2129 Alex
2004-10-23 by ggindele
Those who do business with Digikey - let's send them a quote request for LPC parts and explain why we would love to get it from them. Their quote/feedback page is at: http://dkc1.digikey.com/scripts/us/commcenter.cgi?action=quote Gabe --- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...> wrote:
> > OK, > > let me have a shot at this one. To do business with Digikey takes 2 > participants, Philips and Digikey. We, the apps guys asked for this > coverage many times because we are aware how difficult it is to get > small quantities :-( Unfortunately this is way outside our reach and > there seem to be some differences between the responsible people at > both ends. > > Everybody who would like to buy LPC2000 devices as well as LPC900 > devices from Digikey could do us a great favor by asking Digikey as > well as your local Philips representative if you know him/her why > Digikey does not sell Philips devices. > > So, not only do I understand your frust, I share it. > > Let's keep pushing and pulling at both ends and hope that you can by > and we can sell quantities of 1 through channels like Digikey. > > We will get there, hopefully rather sooner than later. > > Best regards, Robert > > > --- In lpc2000@yahoogroups.com, "R M" <rodlist@r...> wrote: > > > > I hate to respond with a 'me too' post, yet I second this motion. > > > > My company routinely purchases parts from DigiKey, with delivery to > > our door in one or two days (and we are in Canada). As a result I can > > get access to many parts very quickly. > > > > However, to get a few LPC samples, I have to talk to my Philips rep > > (Arrow), who has to talk to Philips, which can take over a week. > > > > And then if I want to purchase trays of parts, it takes a couple of > > weeks for Arrow to deal with our purchasing group, if they have stock. > > DigiKey takes a day or two, no matter the quantity. > > > > So Philips, if you are listening, please get your very wonderful LPC > > line on DigiKey's shelves. I know Atmel will have their new ARM7 line > > available at DigiKey, so should you. > > > > - Rod > > > > --- In lpc2000@yahoogroups.com, "Paul" <Paul@P...> wrote: > > > > > > If anyone from Philips is listening, I can't tell you how many times > > > I've had a situation like this.... and the solution was to order > > > parts from Digikey at 4:30 pm for UPS RED delivery the next morning. > > > > > > I'm sure there's a lot of issues franchising with digikey, but > > > consider that almost all Atmel AVR-tiny and Microchip PIC chips are > > > available tomorrow morning. That's faster than even finding out > > > IF a Philips LPC sample might show up in a week or two. > > > > > > > > > Paul > > > > > > > > > > > > > Philips have greatly streamlined there samples system in the > last few > > > > years - you should be able to get 5pcs free of charge in a week or > > two.
2004-10-26 by R M
Thanks for the response Robert. Excellent idea Gabe - I just filled out a quote. - Rod --- In lpc2000@yahoogroups.com, "ggindele" <ggindele@y...> wrote:
> > Those who do business with Digikey - let's send them a quote request > for LPC parts and explain why we would love to get it from them. > Their quote/feedback page is at: > > http://dkc1.digikey.com/scripts/us/commcenter.cgi?action=quote > > Gabe
