lpc2100_fan <lpc2000@yahoogroups.com> wrote:
> since your last post I learned something new about debugging. The
> Philips implementations of the ARM micros include something called
> Real-Time-Monitor, a ROM monitor that comes from ARM and will be
in the PDF document you mentioned, I only found the term
"RealMonitor": "RealMonitor is a component of ADS, and requires
either Multi-ICE Version 2.0 or ARM ADI". It "uses the target
processor DCC channel" and needs "RMTarget" software running on the
ARM7 (I guess using standard IRQ from DCC).
I found no spec about the CPU cycles needed to transfer one word from
or to target memory - any hint where to look?
Anyway, that's _not_ like Motorola BDM, where unused bus cycles are
used to access target memory. BDM is handled by a piece of hardware
in the uC and doesn't require RAM, ROM or CPU cycles.
In (some of) my applications, I have code portions where the precise
timing is essential (e.g. integrating an analog signal over a 2us
period). If some debug firmware runs hundreds of nanoseconds or even
longer, the device doesn't work as intended.
> (better) supported by an upcoming release of the ARM toolchain. As
> always, it is a matter of tool support but the firmware in the
> microncontroller exists to do background debugging similar or a little
> better than on the Motorola chips without using the Trace feature
> (which costs quite some extra pins but provides Code trace without ANY
> real-time conflicts).
I don't see the advantage over the Motorola solution, maybe I missed
something?
Can I read memory via ETM during program execution?
BTW: there is also a (small) trace buffer in newer HCS12 derivatives.
Oliver
Oliver Betz, Muenchen
