Lpc2000
Olimex LPC2124
Olimex LPC2124
2004-10-20 by s_bencke
Somebody knows if the development kit of Olimex LPC-E2124 came with a
good satck TCP/IP or it is just the hardware?
Thanks
RE: [lpc2000] Olimex LPC2124
2004-10-20 by Paul Curtis
I ported uIP to the E2124, and it's working well.
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, and (soon) Atmel AVR processors
> From: s_bencke [mailto:s.bencke@...]
> Sent: 20 October 2004 20:36
> To: lpc2000@yahoogroups.com
> Subject: [lpc2000] Olimex LPC2124
> Hi,
> came with a good satck TCP/IP or it is just the hardware?
> Thanks
> $9.95 domain names from Yahoo!. Register anything.
> http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/dN_tlB/TM
2004-10-21 by s.bencke
I take a look in the uIP site and I don't find the port for LPC2XXX.  Are you having problems with this stack? Do you recommend it?
Thanks
SB
De:"Paul Curtis" plc@...
Para:lpc2000@yahoogroups.com
Cópia:
Data:Wed, 20 Oct 2004 21:38:33 +0100
Assunto:RE: [lpc2000] Olimex LPC2124
> > Hi,
> > Thanks
> > Yahoo! Groups Links
2004-10-21 by Paul Curtis
> LPC2XXX.
Yes, that's because (as I said) I ported the stack to the E2124 and
wrote the device drivers for it.  I haven't bothered doing much else
with it, Tsvetan wanted to know whether the E2124 could run a simple Web
server, so I moved to code to the board and ran it.  I provided Tsvetan
with the hex file which can be blown into the E2124 using the BSL to
turn it into a web server.
No, I never said I had any problems with it.  I haven't used it other
than to check telnet, ftp, and HTTP services.
I don't recommend anything--who knows whether it fits your requirements?
If you want to see whether it fits your needs, then download and
evaluate the stack yourself and get it ported to the E2124.  I mean, it
wasn't difficult, I read the CS8900A data sheet, read the uIP
documentation, and then wrote the code.  The driver is about 200 code
lines.
