Lpc2000
External address decoding
2004-11-01 by Damon Kelly
I'm considering the LPC221x for a data acquisition device, but I
need multi-megabytes of SRAM (say, 16MB), and several parallel
devices. I'll need multiple devices on the same memory channel, at
different addresses.
Looking at the timing digrams for the address bus, I can't see how
to reliably decode the address bus to generate extra CS signals: CS
and OE can go low before OR after the address lines settle.
Any suggestions on how to qualify CS, OE or WE to allow multiple
devices on the bus?
Re: [lpc2000] External address decoding
2004-11-02 by Bill Knight
You can use XCLK to delay CS.  That will give the address bus time
to stablize.
-Bill Knight
http://www.theARMPatch.com
devices on the bus?
Re: External address decoding
2004-11-02 by Damon Kelly
Not exactly sure what you mean there...
I just found a Sharp App Note about this very topic. They suggest a
flip-flop clocked by XCLK, and Set by nCS, to delay nOE.
I figure clocking nOE on the -ve going edge of XCLK will give half a
cycle delay.
nWE doesn't have the same problem -- it seems to always fall within
nCS and Address Valid.
Damon
> to stablize.
> Regards
> -Bill Knight
CS
> devices on the bus?
2005-10-24 by grapevinetech
The past is coming to life again....
I just found the message below that was sent almost a year ago to the
LPC2000 forum and I'm just attempting to do the same thing as the
original poster.
Having looked at this, I have come to the same conclusion as Bill -
use XCLK to produce a new derived CS dependent on the address. The
question I have is 'how does this affect the required access time for
the device'. The timing parameters given in the LPC2294 data sheet
don't seem complete enough to make this determination. If I knew the
actual point in the cycle when the data had to be valid then it would
be easy, but that isn't specified.
Anybody have any ideas on this?
Andy..
> to stablize.
> Regards
> -Bill Knight
> devices on the bus?
