lpc2104 not executing code in flash
2004-11-02 by manikandan palaniappan
hi, i am using tinyarm lpc2106 from ramtek.i download the example from donotronics mb40_examples.zip(Dontronics - TinyARM DIP40/50 with Philips LPC2106/2129 ... websitefor -www.dontronics.com/pasat.html)for lpc2106.i am using IAR EmbeddedWorkBench version 4.10A for producing intel hex file and downloading code into flash Using philips ISP.program executed successfully.we also having lpc2104 board and i want to do the same example by changing project option in target to lpc2104 chip,compiled and getting intel hex output without any errors.when i downloaded the program into flash it was downloaded successfully ,but it is not executing.i am using uart example to transmit the character typed from keyboard.is there any other setting to be changed?i also need uart example program for lpc2104. Thanks in advance, pl.manikandan --------------------------------- Do you Yahoo!? Check out the new Yahoo! Front Page. www.yahoo.com/a [Non-text portions of this message have been removed]
