Lpc2000
Philips ISP doesn't work with LPC2214?
2004-11-03 by tsvetanusunov
This question is mostly addressed to Philips stff who does monitoring
to this group.
We have preliminary samples of our LPC-H2214 board with external
Flash, SRAM etc. Everything works fine so far when use JTAG
debugging, but when we try to load code in Flash with Philips ISP it
programs the internal Flash, then fails in the middle of verify
operation.
The same situation was with LPC212X microcontrollers with old
bootloader, and everything fixes when new bootloader is burned in the
LPC212X.
So is there other bootloader version for LPC2214 which will cure this
problem?
Dispite ISP tells that verify fails everything is programmed
correctly inside LPC2214, so I guess this is some stupid timing issue.
The LPC2124 is marked TS0432 A
the crystal is 14.7456Mhz
bootloader rev. 1.63
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, and MSP430
(http://www.olimex.com/dev)
Re: [lpc2000] Philips ISP doesn't work with LPC2214?
2004-11-03 by Robert Adsett
>to this group.
>operation.
>LPC212X.
>problem?
A couple of quick questions,
Which version of the ISP utility are you using?
And do you know where in the verify it fails?
the reason for asking is that there is apparently a problem in comparing
the first area of the flash.
See http://groups.yahoo.com/group/lpc2000/message/2953
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: Philips ISP doesn't work with LPC2214?
2.2.0
it fails on the final
comparing
thanks, this explains it all, after calculating vectors in buffer and
save hex, compare now works
any idea why this problem doesn't show on the other LPCs but 2214?
Tsvetan
