Lpc2000
Natural alignment of 32-bit values within structures (gcc 3.4.1)
2004-11-30 by dpbevin2k
I've got a problem accessing 32-bit values within nested structures
using gcc 3.4.1.
I don't know whether it is a problem with compiler flags or because
the output object is fairly large (600Kb) or whether it is because the
nested structure is quite complicated (see below).
Having debugged the source, I can see that a 32-bit value within the
structure is not aligned to a 32-bit boundary (only 16-bit) and
therefore, the STR operation on that element fails.
The structures are as follows:-
<-- BEGIN CODE -->
typedef unsigned char	UBYTE;
typedef unsigned short	UWORD;
typedef unsigned long	ULONG;
typedef enum
  ENUM_ONE,
  ENUM_TWO,
  ENUM_THREE,
  ENUM_FOUR
} SOME_ENUMS;
typedef union
  float  alg_val;
  ULONG  dig_val;
  struct
    UBYTE    fourA;
    UBYTE    fourB;
    UWORD    fourC;
  } indirect;
} OBJECT_FOUR;
typedef struct
  OBJECT_FOUR   twoA;
  OBJECT_FOUR   twoB;
  OBJECT_FOUR   twoC;
  OBJECT_FOUR   twoD;
  OBJECT_FOUR   twoE;
  UBYTE         twoF;
} OBJECT_TWO;
typedef struct
  SOME_ENUMS    threeA;
  UBYTE         threeB;
  UWORD         threeC;
  OBJECT_FOUR   threeD;
  ULONG         threeE;
  ULONG         threeF;
  OBJECT_FOUR   threeG;
  UBYTE         threeH;
  UBYTE         threeJ;
} OBJECT_THREE;
typedef struct
  UWORD         oneA;
  OBJECT_TWO    oneB;
  UBYTE         oneC;
  OBJECT_THREE  oneD;
} OBJECT_ONE;
<-- END CODE -->
When I use a pointer to an OBJECT_ONE object, any accesses to members
within oneB (OBJECT_TWO) fail because the compiler hasn't put a
two-byte pad between oneA and oneB (to preserve natural aligment).
Any help would be greatly appreciated.
Thanks in advance.
David Bevin
Re: Natural alignment of 32-bit values within structures (gcc 3.4.1)
Sincere apologies to all... I am a donkey/arse (sorry ass)!
I found a "#pragma pack" well hidden within the bowels of the source.
> using gcc 3.4.1.
> <-- BEGIN CODE -->
> typedef enum
>   ENUM_ONE,
>   ENUM_TWO,
>   ENUM_THREE,
>   ENUM_FOUR
> } SOME_ENUMS;
> typedef union
>   float  alg_val;
>   ULONG  dig_val;
>   struct
>     UBYTE    fourA;
>     UBYTE    fourB;
>     UWORD    fourC;
>   } indirect;
> } OBJECT_FOUR;
> typedef struct
>   OBJECT_FOUR   twoA;
>   OBJECT_FOUR   twoB;
>   OBJECT_FOUR   twoC;
>   OBJECT_FOUR   twoD;
>   OBJECT_FOUR   twoE;
>   UBYTE         twoF;
> } OBJECT_TWO;
> typedef struct
>   SOME_ENUMS    threeA;
>   UBYTE         threeB;
>   UWORD         threeC;
>   OBJECT_FOUR   threeD;
>   ULONG         threeE;
>   ULONG         threeF;
>   OBJECT_FOUR   threeG;
>   UBYTE         threeH;
>   UBYTE         threeJ;
> } OBJECT_THREE;
> typedef struct
>   UWORD         oneA;
>   OBJECT_TWO    oneB;
>   UBYTE         oneC;
>   OBJECT_THREE  oneD;
> } OBJECT_ONE;
> <-- END CODE -->
> Thanks in advance.
> David Bevin
