Lpc2000
Trouble with simple delay function :-/
2004-12-09 by nourson54
I have written a pause() fonction under crossworks 1.3 like this :
#define ONE_SEC (uint32t)10000000
void pause(uint32_t duration)
  uint32_t startTime = T0TC;
  uint32_t now,temp;
  now=startTime;
  temp=now-startTime;
  while (temp < duration)
	now=T0TC;
	temp=(uint32_t)(now-startTime);
	WDOG();
main
    Inittimer, ports, etc ....
    while(1)
           pause(ONE_SEC);
           IOPIN^=LED;
Then when i want to use this function , it happens strange things :
the first time I calls pause() , when i set a brekpoint on the
function pause the parameter duration passed has a value of 3248002688
instead of 10000000 !!! But at the second call(and others)
duration=ONE_SEC=1000000 in pause() . So my led blink at the good
frequency of 1s .
So , what's wrong ??
thanks in advance
Re: Trouble with simple delay function :-/
I have investigate a little more . It looks like ii's a bug from the
compiler :-/
I set two breakpoints just after the call and it seems the duration
parameter is altered
  uint32_t startTime = T0TC;      <----- 1st BP here,duration=10000000
	uint32_t now,temp;
	now=startTime;            <-- 2nd BP here,duration=3247832688
	temp=now-startTime;
			now=T0TC;
			WDOG();
>   uint32_t now,temp;
>   now=startTime;
>   temp=now-startTime;
> 	now=T0TC;
> 	WDOG();
> main
>     while(1)
>            pause(ONE_SEC);
>            IOPIN^=LED;
> frequency of 1s .
> thanks in advance
another strange thing :
10000000 is 0x00989680
and 3247832688 is 0xC1989680
the compiler seems to alter the high byte of the parameter.
Whys and how , i don't know ...
Someone from Rowley here ? :)
> compiler :-/
> 	uint32_t now,temp;
> 	temp=now-startTime;
> 			now=T0TC;
> 			WDOG();
> >   uint32_t now,temp;
> >   now=startTime;
> >   temp=now-startTime;
> > 	now=T0TC;
> > 	WDOG();
> > main
> >     while(1)
> >            pause(ONE_SEC);
> >            IOPIN^=LED;
> > frequency of 1s .
> > thanks in advance
