Lpc2000
Interrupts during IAP
2004-12-16 by Karl Olsen
Hello all,
Normally all interrupts should be disabled during IAP calls.  But if
the interrupt vectors and all interrupt code are relocated to RAM,
are there any limits as to how much time interrupt handlers
may "steal" from the foreground program during IAP erase/write calls?
Karl Olsen
2005-01-05 by rjwal3
I have set the UART interrupt up to run from RAM so I can use it
during IAP writing to FLASH yet it causes the same problem as if I
were running the interrupt from FLASH.
Does any one have any experience this?
The interrupt vector in startup.s is:
   LDR     PC, [PC, #-0x0FF0]     /* Vector from VicVectAddr */
 And the vector address for my UART1 interrupt is my RAM function:
  VICVectAddr2 =  (unsigned long)u1intRAM;
This works fine by itself, but not when I try to use IAP with the
UART interrupt anabled and all the rest disabled.
Could it still be getting something from FLASH?
Re: Interrupts during IAP
2005-01-05 by Karl Olsen
Have you relocated the interrupt vectors, i.e. copied them from flash
to RAM and changed MEMMAP?
Karl Olsen
I
function:
flash
> Karl Olsen
yes I have copied the interrupt vectors to 0x4000000, and the
interrupt procedures are in RAM as well and MEMMAP = 2.
This All works fine unless I try to use it in conjunction with IAP,
and the IAP works fine provided the interrupt is disabled. I can't
see why it wont work, I guess more research is required.I
2005-01-05 by tom_laffey
Hi Ross,
You might try tracing execution of the ISR in assembly mode to make
absolutely certain that no accesses are made to flash.  This would
include constant data (i.e., initializers inside a function) as well
as code.  Every CPU access must be to RAM or a to a peripheral, since
flash is unavailable during IAP.
Tom
it
if
> I
> function:
> the
> flash
> > Karl Olsen
