Olimex mt2106 and IAR EWARM
2004-12-17 by rproveniers
Hello, I have the following setup: 1-Olimex mt2106 board, you know with LCD display, relay and buttons.. 2-IAR 32K limited Kickstart ARM EWARM 3-IAR i-link USB JTAG pod 4- PC with Windows XP prof. I have tried to port the demo from Senz(@dreamlife) to the IAR compiler. a- if i download original .hex file (from Senz) with Philips ISP.. it works b- the IAR port , flash-debug settings, download with debugger to flash,it works when i remove debug and bst jumpers, right out from flash (after repower) c- i cannot get it to work via the IAR debugger, not in ram or flash, i can activate relay, on/off and toggle leds, but cannot get push-buttons and LCD screen to work??? In the IAR debugger there is complete strange behavior, e.g. IOPIN is not refecting the actual status!!! d- when i make a .hex file with EWARM and download it with Philips ISP it works fine!!! It looks like i am doing something wrong, but what???? I have the feeling that the IAR debugger is not working with I-LINK JTAG pod... Somebody has a clue?? Thanks in advance Ron
