Lpc2000
LPC2214 possible bootloader rev. 1.63 problem
2004-12-17 by tsvetanusunov
we have production run of boards with LPC2214 and LPC2294, these are
our LPC+external memory header boards and LPC+external
memory+ethernet boards.
On about 20% of the boards Philips ISP utility fail to program the
code on speed above 19200. Everything seems like baudrate problem as
if 19200 or lower speed is used ISP programs everything just fine.
chip info is:
LPC2294JBD144
CD2664	03
TS0434 A
PART ID - 84016915
boot loader ID - 1.63
XTAL freq - 1 474 600 Hz
I sent this info to Philips but they seems to not have time to reply
(season Holidays are aproaching ;), so I wonder if anyone else have
had the same problems? is there newer bootloader release which to fix
these issues?
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, and MSP430
(http://www.olimex.com/dev)
RE: [lpc2000] LPC2214 possible bootloader rev. 1.63 problem
2004-12-17 by Richard Rauscher
We experienced the same behavior when upgrading to 1.63 on the 2114.
Please let me know if you hear of a solution.
--rich
	Sent: Friday, December 17, 2004 10:14 AM
	To: lpc2000@yahoogroups.com
	Subject: [lpc2000] LPC2214 possible bootloader rev. 1.63 problem
are
problem as
fine.
	chip info is:
	LPC2294JBD144
	CD2664      03
	TS0434 A
	PART ID - 84016915
reply
have
to fix
	these issues?
	Best regards
	Tsvetan
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129ob5ngt/M=294855.5468653.6549235.3001176/
D=groups/S=1706554205:HM/EXP=1103393670/A=2455396/R=0/SIG=119u9qmi7/*htt
p://smallbusiness.yahoo.com/domains/>
<http://us.adserver.yahoo.com/l?M=294855.5468653.6549235.3001176/D=group
s/S=:HM/A=2455396/rand=192864127>
	Yahoo! Groups Links
	*	To visit your group on the web, go to:
		http://groups.yahoo.com/group/lpc2000/
	*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
	*	Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service <http://docs.yahoo.com/info/terms/> .
Re: LPC2214 possible bootloader rev. 1.63 problem
2004-12-17 by acetoel
My chip says
LPC2214FBD144
CD2662  10
TSD435 A
Are this chips loaded with bootloader 1.63?
Thanks
Ezequiel
--- In lpc2000@yahoogroups.com, "tsvetanusunov" <tusunov@m...> wrote:
> Hi,
are
as
> chip info is:
> LPC2294JBD144
> CD2664	03
> TS0434 A
> PART ID - 84016915
reply
have
fix
> these issues?
> Best regards
> Tsvetan
2004-12-17 by Leighton Rowe
> Hi,
are
as
I experience this problem quite frequently on my 2114 board (1.63
bootloader), especially at 115k baud speeds. Using a 14.7456 Mhz I
expected updating to be at least hassle free at high bauds (2114
user manual). However, the process tends to halt & fail somewhere in
the middle. Normally I'd resort to retrying the update until it
eventually completes. I'm having the success with 56k baud & below
speeds and below, with less halts occuring at 56k. Keep me posted if
u've found the cause of this problem.
Leighton
startup file ADS 1.2
2004-12-20 by Muraletharan Kulasekaram
I need start up file of LPC2129 to use with ADS V1.2
ANY ONE HELP ME ?
___________________________________________________________
ALL-NEW Yahoo! Messenger - all new features - even more fun! http://uk.messenger.yahoo.com
Re: startup file ADS 1.2
2004-12-20 by Amit
Check out the Interrupt handling application note online. The code
was built on ARM ADS1.2. This application note has the startup
assembly code for the LPC.
http://www.semiconductors.philips.com/acrobat_download/applicationnote
s/AN10254_2.pdf
amIT..
--- In lpc2000@yahoogroups.com, Muraletharan Kulasekaram
> ANY ONE HELP ME ?
2005-07-15 by markcrow
I just recently discovered that if your ISP tool (by whomever) fails
at a higher baud rate it is probably because of three issues:
1. There is an error in the Philips LPC2xxx User Manual.  All
commands sent to the bootloader do not require a C/R and a L/F; in
fact only a C/R is required.
2. If the ISP software validates all returned commands it will fail
to compare, for instance, "Synchronized[c/r][l/f]OK[c/r][l/f]" which
it expects after transmitting the command "Synchronized[c/r][l/f]"
with "Synchronized[c/r]OK[c/r][l/f][l/f]" which it actually
receives.  Obviously the bootloader sent the "OK[c/r][l/f]" when it
received the C/R in the "Synchronized[c/r][l/f]" command and then
received and echoed the L/F later.
3. Bootloader response behavior in this case is transmit
latency/inter-byte gap/baud rate dependent.
I do not know if this will be only a V1.63 issue and have sent an
email to my Philips FAE regarding this whole problem.  I'll let
everyone know what develops.
--- In lpc2000@yahoogroups.com, "Leighton Rowe" <leightonsrowe@y...>
wrote:
> > Hi,
> are
> as
in
if
> Leighton
