I'm been pretty happy using the gnu toolchain w/ the USBDemon (fast).
On 7/15/05, Jim Parziale <nuncio.bitis@...> wrote:
> "Shut down sockets." *is* the error message returned from OCDRemote. It
> seems to just shut down when Insight successfully connects (yes, I get a
> "connected successfully" window pop up). I've also noticed that the process
> goes away (using Windows task manager)
> I'm suspecting this is the pins 8-15 short problem with the Wiggler (well,
> not a problem with the Wiggler, but with the tools), although I don't see
> why this would start happening now after using the tools for a while,
> unless
> the tools have a time limit. I'm using OCDRemote v2.12a, and I suspect I
> didn't have this problem with v2.12, since that's the version I started
> using, and Insight was working back then.
> I've got a bunch of things to try out this weekend now: clock speed (I hear
> "-s 8" works best), OCDRemote v2.13, OCDRemote v2.12, connect pins 8 and 15
> on the Wiggler.
> I looked into the Rowley Crossworks toolkit, but it's very expensive
> (probably around $700US)
> I'm writing to Keil to get quotes on their tools. I'm going to try the
> evaluation of their tools though.
> A 16K limit on code size doesn't make me too happy, although I have yet to
> come close to that with my code.
> Thanks
> On 7/15/05, Bryce Schober <bryce.schober@gmail.com> wrote:
> > On 7/15/05, nuncio_bitis <nuncio.bitis@...> wrote:
> > > I've recently started having problems with OCD Remote
> > > I can start it up with the command :
> > > ocdremote.exe -cARM7TDMI-S -p8888 -dWIGGLER -a1 -s6
> > > (note - no other speed besides 6 works)
> > > I then start up arm-elf-insight.exe (part of GNUARM)
> > > I can connect to target, and download to RAM (which is super slow -
> > > takes a few minutes to download 1500 bytes), but when I try to start
> > > running, OCDremote shuts down with error:
> > > Shut down sockets.
> > It would be more informative to see the error generated by OCDRemote.
> > That usually has more details as to the cause of the failure.
> > Bryce Schober
> > YAHOO! GROUPS LINKS
> > - Visit your group "lpc2000
> <http://groups.yahoo.com/group/lpc2000>"
> > on the web.
> > - To unsubscribe from this group, send an email to:
> lpc2000-unsubscribe@yahoogroups.com<lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > - Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service <http://docs.yahoo.com/info/terms/>.
> Jim Parziale
> Email: nuncio.bitis@...
> Malden, MA
> YAHOO! GROUPS LINKS
> Visit your group "lpc2000" on the web.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Bryce Schober
