--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@y...>
wrote:
> Rick,
> there are even two versions of the UM in the files section. The Data
> sheet can be downloaded from Philips.
> http://www.semiconductors.philips.com/pip/LPC2131FBD64.html
Yes, I found the UMs and I already have the data sheet from the
Philips site. I thought someone indicated that an up to date data
sheet was available, but I must have misunderstood. The data sheet is
still incomplete with TBDs.
Some of my questions have been answered here in another thread and the
RTC power requirement is too high to use as a conventional RTC. It
requires about 10 to 40 times the current of a standard RTC chip even
though it has an independant power source. If I needed the power of
the ARM CPU with the low current of an RTC, the Atmel AT91M55800A is
still a much better choice. I don't really need the horse power of
the ARM chip, but at the low price I thought it might fit the socket.
But it doesn't do the RTC job well enough.
> --- In lpc2000@yahoogroups.com, "Rick Collins" <OKI-ARM-mcus@a...>
wrote:
> > --- In lpc2000@yahoogroups.com, "johnnorgaard2003"
<john_2005@c...>
> > wrote:
> > > Hi Jan
> > > I have uploaded it to files section.
> > > best regards
> > > John
> > > > John,
> > > > Where did you find a User Manual, I have only preliminary
> > > > specifications. Can you send a link ?
> > > > Jan
> > Hmmmm, the only DS I can find in the files section is a
preliminary
> > copy. Is there a file I am missing?
