Lpc2000
Why the buffer in Leon's JTAG interface?
2004-12-30 by tkreyche
I'm laying out a board to test the LPC2138 and looked at circuit
diagrams for various 2106 and 2138 boards, to get the JTAG right.
Some of the diagrams (see Leon's in the file section) use a 74x244 to
buffer the JTAG signals and optionally a transistor on the reset
line. The Keil 2138 board only uses a few pull-up/pull-down
resistors, no buffer/transistor (there are a few minor differences
between 2106/2138 on activating JTAG).
On the IAR 2106 board I figured they did it just to isolate signals
between the primary/secondary JTAG ports.
I don't see any compelling reason to use the buffer unless you prefer
to zap the buffer with static rather than the LPC. Or maybe if you
have a questionable JTAG-parallel/usb converter.
Anybody (Leon?) have any insight?
thanks, Tom
Re: Why the buffer in Leon's JTAG interface?
2004-12-31 by leon_heller
to
prefer
Signal integrity is important with interfaces like JTAG - clean sharp
pulse edges are required for proper operation, although the
frequencies are low. A buffer might not be essential in every case,
but the cost is minimal, so it's a good idea to use one.
Manufacturers' JTAG interfaces for other devices like FPGAs are
always buffered, although I have heard of people getting away without
them by keeping the leads short.
Leon
