Lpc2000
Defining /cygdrive/ for GNUARM output
2005-01-01 by sig5534
After getting the GNUARM installed, when I do a make I get the
following output:
main.o(.text+0x10): In function `main':
/cygdrive/d/GNUARM/Projects/Vader/main.c:172: undefined reference to
`Init_CPU'
main.o(.text+0x24):/cygdrive/d/GNUARM/Projects/Vader/main.c:198:
undefined reference to `Init_Display'
main.o(.text+0x28):/cygdrive/d/GNUARM/Projects/Vader/main.c:293:
undefined reference to `MA_ReadPort_GPIO'
main.o(.text+0x48):/cygdrive/d/GNUARM/Projects/Vader/main.c:294:
undefined reference to `VaderData'
collect2: ld returned 1 exit status
NMAKE : fatal error U1077: 'arm-elf-gcc' : return code '0x1'
Stop.
The file listings contain this "/cygdrive/d" portion like:
The true path should be:
D:/GNUARM/Projects/Vader/main.c
How do I define this /cygdrive/ variable so I can get accurate paths
listed in the output?
Thanks,  Chris.
Re: [lpc2000] Defining /cygdrive/ for GNUARM output
2005-01-01 by yue yue
This is not wrong. You may try to use cd /cygdrive/d/  or cd /d: .
and then use pwd.  I think you will understand what happened in cygwin environment.
I think NMAKE is different from make (GNU maker). Pls use make.
following output:
`Init_CPU'
Stop.
Thanks,  Chris.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
Do You Yahoo!?
注册世界一流品质的雅虎免费电邮
