Lpc2000
LPC2138: Strange SSP Behavior
2005-01-10 by tah2k
I'm writing the driver for the LPC2138 SSP block and I am
encountering some strange behavior:
First of all, the user manual states SSPCR1, SSPCPSR, and SSPIMSC
are all reset to 0x0 upon powerup.
I am finding the following values in these registers after reset:
SSPCR1 (0xE005C004): 0xF8
SSPCPSR (0xE005C010): 0x04
SSPIMSC (0xE005C014): 0x04
The processor ignores any writes of any data value to these
locations.
Any ideas?
-Tim
Re: LPC2138: Strange SSP Behavior
2005-01-11 by johnnorgaard2003
Hi
Have you selected the SSP function in PINSEL0 or PINSEL1 ?
best regards
John
> locations.
> Any ideas?
> -Tim
2005-01-11 by tah2k
Yes, but it doesn't seem to matter.
--- In lpc2000@yahoogroups.com, "johnnorgaard2003" <john_2005@c...>
wrote:
> Hi
> best regards
> John
SSPIMSC
> > locations.
> > Any ideas?
> > -Tim
RE: [lpc2000] Re: LPC2138: Strange SSP Behavior
2005-01-11 by Charles R. Grenz
	Do you have the slave select pin pull high?
Charles
Sent: Tuesday, January 11, 2005 9:59 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Re: LPC2138: Strange SSP Behavior
wrote:
> Hi
> best regards
> John
SSPIMSC
> > SSPCR1 (0xE005C004): 0xF8 SSPCPSR (0xE005C010): 0x04
> > locations.
> > Any ideas?
> > -Tim
Yahoo! Groups Links
2005-01-11 by tah2k
It is pulled high, but the issue I am having is the memory locations
themselves.
--- In lpc2000@yahoogroups.com, "Charles R. Grenz"
<charles.grenz@s...> wrote:
> Hi,
> Charles
> From: tah2k [mailto:tah2k@y...]
<john_2005@c...>
> wrote:
> > Hi
> > best regards
> > John
> SSPIMSC
reset:
> > > locations.
> > > Any ideas?
> > > -Tim
Hi
	Was just wondering. I have seen strange behavior from the SPI on a
2106 from time to time related to the slave select (may have also been the
programmer!).
	I would double check all your clock and divider settings. Any other
registers you are having trouble with as well? Have you tried writing or
reading from the standard SPI?
	I'm interested in this because I will be using the SSP very soon
myself.
Charles
Sent: Tuesday, January 11, 2005 11:16 AM
themselves.
> Hi,
> Charles
<john_2005@c...>
> wrote:
> > Hi
> > best regards
> > John
> SSPIMSC
reset:
> > > SSPCR1 (0xE005C004): 0xF8 SSPCPSR (0xE005C010): 0x04 SSPIMSC
> > > (0xE005C014): 0x04
> > > locations.
> > > Any ideas?
> > > -Tim
Yahoo! Groups Links
2005-01-11 by beedward2
I would check the addresses for the SSP control registers.  The user
manual I have (11/22/04) has the following addresses:
SSPCR1  : 0xE0068004
SSPCPSR : 0xE0068010
SSPIMSC : 0xE0068014
The addresses you specify map to the I2C port.
0xE005C004 = I2C1STAT; 0xF8 at reset
0xE005C010 = I2C1SCLH; 0x04 at reset
0xE005C014 = I2C1SCLL; 0x04 at reset
I think this explains your problem.
Good luck,
Ben
> themselves.
> > Hi,
> > Charles
> <john_2005@c...>
> > wrote:
> > > Hi
> > > best regards
> > > John
> > SSPIMSC
> reset:
> > > > locations.
> > > > Any ideas?
> > > > -Tim
> > Yahoo! Groups Links
2005-01-11 by tah2k
Yes! Your right. My User Manual is dated August 25, 2004 and both
the I2C and SSP have the same base address!
Thanks a bunch-
Tim
user
> SSPCR1  : 0xE0068004
> Good luck,
> Ben
locations
> > themselves.
> > > Hi,
> > > Charles
> > <john_2005@c...>
> > > wrote:
> > > > Hi
> > > > best regards
> > > > John
> > > SSPIMSC
> > reset:
> > > > > locations.
> > > > > Any ideas?
> > > > > -Tim
> > > Yahoo! Groups Links
