Lpc2000
LPC2000 and EMC radiation (Application radio modems)
2005-01-24 by phlpcmicro
Hi All,
Some micro's have terible radiation characteristics and are
unsuitable to in radio modems with sensitive analogue frontends.
ARM controllers are used in mobile phones  etc.
What characteristics do the LPC2000 have that lend thenselves
radio modems / phones etc.
ie: Sloped I/O output?  Small LQFP packes....
Q
Are there other EMC radiation factors to consider.
Thanks in Advance.
Joseph
Re: LPC2000 and EMC radiation (Application radio modems)
2005-01-24 by tsvetanusunov
this is very interesting topic, I can't find any info on this in LPC
datasheets, but we found interesting feature: when LPC PLL is enabled
if you have near by (1-2 meters) FM radio you can hear the sweep tone
for about second.
Our QC found this as they have radio on their desk where LPC boards
are tested, no one of other microcontrollers we used make such
interference to the radio.
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, and MSP430
(http://www.olimex.com/dev)
2005-01-24 by charlesgrenz
Hello,
  I am currently in the middle of a design for the 2138. EMI is very
important in the design.
   Are you used multilayer boards? How about series resistors on all
the lines (both input and output)? Do you have a resistor in series
with the XTAL2 output? How about 100pF capacitors on all the I/O that
goes off the board. What crystal frequency are you using? How about
ferrites on all level transistion devices (like RS232 and such)?
Thanks
Charles
> for about second.
> Best regards
> Tsvetan
Hi Charles,
Thanks for the suggestions - all relivant details.... However some
cores do radiate abormally higher than others.
Using an RF probe and a spectrum analyser over the package you
CAN see the difference in radiation levels of noisy cores.
Yes - there are methods to "sheild" noisy cores - but - why start
with one in the 1st place.
Philips did an app note 10~15years ago discussing the advantages of
LQFP over DIP in relation to RF EMC radiaion characteristics.
Joseph
--- In lpc2000@yahoogroups.com, "charlesgrenz" <charles.grenz@s...>
wrote:
> Hello,
very
all
that
> Thanks
> Charles
frontends.
LPC
enabled
tone
> > for about second.
boards
> > Best regards
> > Tsvetan
Hi Joseph,
   To true. The real question is the LPC2138 one of those processors?
If so, then we may have to box it.
reagards,
Charles
--- In lpc2000@yahoogroups.com, "phlpcmicro" <joseph.goldburg@a...> wrote:
> Hi Charles,
> Regards
> Joseph
> wrote:
> > Hello,
> very
> all
> that
> > Thanks
> > Charles
> frontends.
> LPC
> enabled
> tone
> > > for about second.
> boards
> > > Best regards
> > > Tsvetan
> Hello,
that
we use double side board, the problem is not in the crystal
definitely as if PLL is not enabled this noise is not generated
IIRC PLL works on 150-180 Mhz and the radio iterference is caused
probably when PLL frequency pass through 108Mhz FM range
Best regards
Tsvetan
Re: [lpc2000] Re: LPC2000 and EMC radiation (Application radio modems)
2005-01-24 by Marko Pavlin (home)
It's not easy and there are only well known general rules. Use emi
filters on high speed lines where possible (e.g. murata EMIFIL or
similar), use ground shielding as much as possible. Avoid current
flowing through shielding / ground planes. Add external shield if
nothing else works. It's tough task. I had similar issues with smaller
MCU (x51), which was solved with EMI filters and grounding with 4-layer PCB.
M.
tsvetanusunov wrote:
> > Hello,
> that
> Best regards
> Tsvetan
> (http://www.olimex.com/pcb) <http://www.olimex.com/pcb%29>
> <http://www.olimex.com/pcb/protoa.html%29>
> (http://www.olimex.com/dev) <http://www.olimex.com/dev%29>
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
>       http://groups.yahoo.com/group/lpc2000/
>     * To unsubscribe from this group, send an email to:
>       lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-01-24 by microbit
> M.
> > Best regards
> > Tsvetan
Your best shot I think is to try and isolate *where* the VCO signal is radiating,
little chance it would radiate so strongly from the die !
Probably like Fvco/2 or thru some divider, it is leaking onto a Vdd line (or also Vss)
and radiating from there.
The best attack - if this signal should be a problem - is to bypass the proper track(s)
as cose as possible to LPC to a solid GND, with a low inductance return path to the chip.
Worst case you must find where the leakiest signlas are, and terminate them.
Remember, at 100-200 MHz, 100 nF is a _very_ unsuitable bypass capacitor.
Bypass caps should be as low as possible in value, I doubt that EMI filters will do much in
this specific scenario, chances are that by the time the sigs get to the EMI filter, they've
already been radiating galore anyway. They must be bypassed to GND, and their energy
returned to LPC2000.
Good luck,
Kris
2005-01-24 by Robert Wood
Sorry if someone's already mentioned it, but big, dobbering ground planes are
the single most effective way I've found over the years for helping with
this.
There was one board that we struggled with for ages. I kept telling my boss we
needed to go multi-layer. After wasting weeks of time and loads of money he
finally agreed to trying a multi-layer board. Guess what? It passed no
problem after that.
Yep, all those things we've done. Top of the board is 100% components
and 99% signals and the bottom is 1% signal and 99% ground plane. Top
of the board that is not used by traces is also a ground plane. Took a
while to lay it out, but it's better then going multilayer. I also
added CTS resistor arrays right next to the processor. They are great
since they have 8 single resistors on 0.5mm centers. My capacitors on
the other hand are at the connector locations which is about 3 inches
away (100pF).
I was just wondering if anyone of the LPC processors has EMI
experience? We recently went throught this with the PXAG49 processors
from Philips and found that the control lines are very noisy at 29.4xxMHz.
regards,
Charles
planes are
with
> this.
my boss we
money he
> problem after that.
Hmmm, the only other thing I can suggest is looking at any long lines with
high speed data on them (especially clock lines). I found that putting a
resistor on long lines to round off the signal a bit and stop ringing really
helped.
Good luck, EMC's a real PITA!
away (100pF).
regards,
Charles
planes are
with
> this.
my boss we
money he
> problem after that.
Yahoo! Groups Links
2005-01-25 by tlarson_greatnotions
I have a board built with the LPC2214.  This board has 3 LDO's, a
rectifier bridge and two offboard connectors and is also two layer.
It is one of the cleanest micros I have ever worked with.  Without
knowing more about the board (and other components) it would be very
hard to say what will turn out to be the source of the interference.
Throwing ferrites and cap's on the board can be counter productive
without knowing the frequencies that are causing
the problem. Do you have access to a spectrum analyzer? This is
probably the most critical tool needed to diagnosis the problem.
Also be aware, that even though your crystal is a lower frequency,
edges internal to the part(s)will occur much faster, as well as
harmonics of the fundamental frequency.  One you have the
frequencies and magnitude involved, then it's possible to formulate
a strategy.
I believe most all the obvious fixes have been discussed already,
but I did not see anyone ask about your trace lengths, width and
spacing, as well as are there traces that run along the edge of the
board.  Do you have any traces that change direction by more than 45
degrees?  Are there any floating pins?  make sure you drive or
pull/up down any pin without a built in pull up/down.  Are you using
the A2D's?  If so, is your analog ground separated from your digital
ground?
Just to illustrate how many different things that can go wrong in a
complex system.  I bring up my own "nightmare" board (non LPC cpu).
In the end we were able to get all into compliance. There were
several small boards and one machine casting that turned out to be a
great ground plane for picking up and transmitting RF.  All but one
board was designed overseas, with parts purchased overseas.  The
main board with the CPU we designed here in the USA for our
customer.  The board drove several motors, Brushed-DC and a couple
of Stepper Motors.  Between the Brushed-DC motor and the power
supply and one fast CPLD.
To fix, we ended up changing the CPLD for a slower,  competitive
model.  The motors and power supply could not be changed do to cost
considerations (consumer white goods).  The excess emissions were
primarily broadband noise.  And not a multiple of the crystal.
Turns out the diode rectifier was the primary source of the
broadband noise.  Slight upgrade in parts here as well as a few well
chosen capacitors in parallel and one ferrite bead solved most of
the problems here.  The rest had to do with long wires coming off
the board to sensors and to the motors.  Again choosing the right
set of capacitors and inductors to filter the signals helped again.
On a couple of stubborn traces, we changed the impedance.  All in
all, I think we ended up adding about $2 to the BOM.
Tim Larson
Great Notions
BTW: Going to four layer did not help in this case... It cleaned up
the lower frequencies, without much effect to the 700Mhz and beyond.
Of course, YMMV
components
Top
Took a
great
on
inches
> away (100pF).
processors
29.4xxMHz.
> regards,
> Charles
2005-01-25 by microbit
Hi Tim,
> the problem.
Exactly, and I've seen this in practice - engineers going "the safe side" with
4 layers, and creating more bad than good.
I'm not opposed to 4-layer per se, but for mixed a really careful layout with
2 layers often suffices if you know the quircks a bit.
Indeed, with near field probe on speccie, you can tell a lot.
> a strategy.
Half indifferent, you'd have to drive the Xtal pretty hard to cause this,
and premature aging/drifting/life time will be badly compromised.
But nothing a good old series resistor won't fix, drive-wise.
> board.
I rasied this issue a while ago on MSP430 group, and a heated discussion
"fobbed" this all off, dismissing as "unnecessary" for digital < 30 MHz.
Well you could have 4-8 MHz clock high slew rate bus signals on "long"
tracks, that are completely the wrong impedance, terminate really poorly,
and cause heaps of EMI.
If this is mastered, it's almost a challenge/game to do something on 2 layers
instead of 4 :-)
> degrees?
Another important one, along with NOT using vias on clock/crystal lines !
B rgds
Kris
2005-01-25 by charlesgrenz
Hi Tim and Kris,
  Thanks for the info. Already performed all those things. This
particular board layout can have from 2 to 3 processors on it
(LPC2138) and we have several experts in EMI in Australia looking the
board over as a second opinion. We learned from other designs using
the PXAG49 that separate crystals with no vias is a must. We get
fundamental frequencies usually in the 110 to 150MHz range with a
29.4xxMHz clock when we had just 1 crystal line feeding the
processors. We will find out soon enough when one of the designs with
the new processors hits the testing range in the second week of
February. In terms of equipment, no. So its testing at a lab. and us
adding and subtracting parts.
regards,
Charles
--- In lpc2000@yahoogroups.com, "microbit" <microbit@c...> wrote:
> Hi Tim,
> > the problem.
side" with
layout with
> > a strategy.
this,
> > board.
poorly,
2 layers
> instead of 4 :-)
> > degrees?
lines !
> B rgds
> Kris
