High Temp application
2005-02-10 by fl429
2005-02-10 by fl429
Hi, Folks, Has anyone tried these chips in a very high temp environment, around 150C, typical downhole in the gas and oil industry ? How do they fare ? Thanks a lot, Lei
2005-02-10 by Rick Collins
--- In lpc2000@yahoogroups.com, "fl429" <fl429@y...> wrote: > > Hi, Folks, > > Has anyone tried these chips in a very high temp environment, around > 150C, typical downhole in the gas and oil industry ? How do they > fare ? Don't know, but ADI makes similar chips that are rated to 125C. I expect that might be a better starting point. I got pricing on the ADuC7024 of $9 for the full -40 to 125C version. The analog IO on the ADI parts is very good too. Some have 16 bit ADC. There is an ADuC forum at http://groups.yahoo.com/group/ADuC_ARM
2005-02-10 by lpc2100_fan
Lei, this will be up to experiments not to specification from Philips I guess. There will be no tested devices running at or above 150C but I am very sure they run for a while. You will not have the chance to reprogram the Flash at least I would not recommend to do that at 150C and these high temperatures are used for stress test, aging the device with a factor of ?? (could be 10, 100 or more). I was present when this subject was discussed at an Embedded Conference and those guys had used the LPC2106 and the LPC2129 for similar tests and found the running several hours above 180C. If I remember correctly they quit above 200C. You might have problems with a desintegrating board at these temperatures anyhow. Am I correct that you are talking hours / days at the max of operating life time or do you expect months / years? If it is months, I doubt you will find a lot of devices for these temp ranges. --- In lpc2000@yahoogroups.com, "fl429" <fl429@y...> wrote:
> > Hi, Folks, > > Has anyone tried these chips in a very high temp environment, around > 150C, typical downhole in the gas and oil industry ? How do they > fare ? > > Thanks a lot, > > Lei
2005-02-10 by Charles Manning
On Friday 11 February 2005 04:07, fl429 wrote: > Hi, Folks, > > Has anyone tried these chips in a very high temp environment, around > 150C, typical downhole in the gas and oil industry ? How do they > fare ? > > Thanks a lot, If parts are only rated to 70C or so, then running them at 150 would seem to be asking for trouble. I'd think that if you designed a 70C part into an 150C environment you'd find a bunch of lawyers gnawing on your bones pretty soon. I'd design in a higher-temp part or use peltier cooling etc to get the temp in the right range for the part. There are some things you can do to promote reliable operation under higher temperatures. The most important is probably to run at slower clock speeds.
2005-02-10 by Joseph Goldburg
Can you put in a box that has insulation?
-----Original Message----- From: fl429 [mailto:fl429@...] Sent: Friday, 11 February 2005 2:07 AM To: lpc2000@yahoogroups.com Subject: [lpc2000] High Temp application Hi, Folks, Has anyone tried these chips in a very high temp environment, around 150C, typical downhole in the gas and oil industry ? How do they fare ? Thanks a lot, Lei Yahoo! Groups Links
2005-02-11 by Rick Collins
--- In lpc2000@yahoogroups.com, Charles Manning <manningc2@a...> wrote: > On Friday 11 February 2005 04:07, fl429 wrote: > > Hi, Folks, > > > > Has anyone tried these chips in a very high temp environment, around > > 150C, typical downhole in the gas and oil industry ? How do they > > fare ? > > > > Thanks a lot, > > If parts are only rated to 70C or so, then running them at 150 would seem to > be asking for trouble. I'd think that if you designed a 70C part into an 150C > environment you'd find a bunch of lawyers gnawing on your bones pretty soon. > I'd design in a higher-temp part or use peltier cooling etc to get the temp > in the right range for the part. > > There are some things you can do to promote reliable operation under higher > temperatures. The most important is probably to run at slower clock speeds. I have never done downhole designs myself, but my understanding is that they don't expect units to be long lived. They can consider them to be expendable if they work ok until they poop out. As long as the MTBF does not go to minutes, which I don't expect, running at 150 C should be no biggie. But like you said, the part will need to be run at a slower speed because of the slower silicon speed at higher temps. Peltier might be an interesting way to cool such a part, but they are also semiconductor (not sure of the material) and may also poop out at high temps.
2005-02-11 by philips_apps
We have internally qualified the CAN type devices (all that include a "9") for operation up to 125C. The problems related to high temp are reduced speed and high stress / shorter life of the devices. Different devices manufactured in the same process will show very similar temperature behaviour. All LPC2000 devices available today, except the flashless versions, are manufactured in the same flash process. We can run our LPC2000 devices at 60 MHz with an ambient temperature of 125C, nevertheless, there is no qualified test equipment for 150C or higher that we would have available. As previously mentioned by other members, provided a few hours life cycle combined with reduced speed, let's say 40-50 MHz, and no reprogramming while hot, I would expect the devices to work properly. Unfortunately Philips will not be able to guarantee operation under these conditions. It is up to test runs at your end, sorry! Hope this helps, Robert --- In lpc2000@yahoogroups.com, "fl429" <fl429@y...> wrote:
