Lpc2000
LPC2106 fails to start with fast power slew rate???
2005-02-17 by dharmaBum
I'm working on a design that uses a LPC2106, but the design will be
migrating to the LPC2138 on the next revision of the PCB.
The LPC2106 seems to have difficulty starting (code does not seem to
be executed) when the power supply slew rate exceeds a certain
rate.  I don't yet have detailed measurements as I just stumbled
across this in the lab.
I will post the numbers after I do some careful measurements of the
3.3 and 1.8 volt slew rates.  If I can determine what the CPU is
doing via the JTAG interface, I will share that too.
Certain FPGAs are notorious for sensitivity to power supply slew
rates. Power slew rates can be too fast as well as too slow.  A
precedent for this weird behavior does exist.  Hopefully, I'm being
mislead by something else or have just lost my mind entirely.
RESET is asserted for 200 ms after the power supply voltages are
stable, then released.  The PCB is 12 layer, controlled impedance
design with a great deal of bypassing and filtering.
Has anybody else observed this kind of LPC2106 behavior?
Wayne
Re: [lpc2000] LPC2106 fails to start with fast power slew rate???
2005-02-17 by microbit
Hi Wayne,
If RESET is really held low for that time, then the slew rate shouldn't
matter
AFAIK. Are you sure nRST and nTRST are sound ?
Boot pin ? Held properly while RESET is de-asserted ?
This might result in erratic entry into bootloader etc.
B rgds
Kris
2005-02-17 by Wayne Radochonski
Kris
Yes, all of those things you mentioned have been checked.  They work fine with the certain lower output current power supplies.
The only thing that looks different is the slew rate.
Thanks for your suggestions
Wayne
microbit <microbit@...> wrote:
Hi Wayne,
matter
B rgds
Kris
Yahoo! Groups SponsorADVERTISEMENT
document.write('');
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
Do you Yahoo!?
 Yahoo! Search presents - Jib Jab's 'Second Term'
Re: LPC2106 fails to start with fast power slew rate???
2005-02-17 by tsvetanusunov
to
check the LPC2106 revision, if it's REV.B search the messages for the
latchup problem with LPC2106
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, MAXQ2000 and MSP430
(http://www.olimex.com/dev)
Re: [lpc2000] Re: LPC2106 fails to start with fast power slew rate???
Tsvetan
Thanks for the insight and yes, these are rev B parts on my board.  I will search the list
for "latch up".
Thanks again,
Wayne
to
Best regards
Tsvetan
document.write('');
Yahoo! Groups Links
Do you Yahoo!?
