Watchdog and external Interrupt problem
2005-02-27 by itsjustimpossible
Hi I am nearing the end of our first project with the LPC2294 and need to implement the watchdog. I am pretty sure I have it setup correctly, and with it in its debug mode I can cause a jump to the watchDog IRQ routine when I put the uP into an endless loop. As part of its functionality external interrupts are disabled until the equipment is set to GO, and this where the problems start. As soon as I enable the external interrupt the watchdog timer jumps to its ISR. (The external interrupts are set to FIQ and at 8uS intervals) Even with the watchdog timer set to a very very long timeout (i.e. ten seconds) as soon as external interrupts are enabled we jump to the WatchDog ISR. With the watchdog set to Off everything else works as expected. With the watchdog set to On but no external interrupts everything works as expected. When I kick the watchdog I am disabling all the interrupts using the VIC. Do I have to jump to system mode and disable the global IRQ and FIQ flags? This would probably be too slow... Has anyone else seen anything like this? At the moment its driving me nuts. many thanks Simon
