Lpc2000
A couple questions on Software Interrupts
2005-03-01 by Leighton Rowe
I haven't played around swi's much but most (if not all) swi_handler
examples that I've seen were written in straight assembly language
(some even containing "swi" instructions).
However from lpc User Manual, I noticed that 2 registers VICSoftInt
& VICSoftIntClear are used to force software interrupts.
How different will the swi_handler be should I use the 2 SoftInt
Registers available?
Would I be able to use a c-style case structure on VICSoftIntClear?
thanks in advance,
Leighton
However,  and looking through ARM7 Programming guides, there seems
to be multiple ways of my I'm picking up two ways in which From the
User Manual
Re: [lpc2000] A couple questions on Software Interrupts
2005-03-01 by Robert Adsett
I think you are confusing two different things.  The SWI op-code generates
an exception to the SWI exception handler not the irq exception
handler.  VICSoftInt is used to generate an IRQ exception which is a
different beast and will end up being vectored through the VIC as the HW
interrupts are.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: A couple questions on Software Interrupts
generates
a
the HW
> interrupts are.
> Robert
Oh ok. Didn't realize setting "VICSoftInt" bits actually
forces "IRQ "exceptions. It makes the whole concept a bit confusing,
but I get the idea. Thanks for the clarification.
Leighton
