Lpc2000
C union not working
C union not working
2005-03-17 by Leonardo Santos
Hello All:
	I'm working with a LPC2106 using the GCC 3.4.4 toolchain (GCC + binutils 2.15
+ newlib 1.13).	I wrote a union and a structure to access the P0 pins
individually, like this:
typedef struct {
	int p0	: 1;
	int p1	: 1;
	int p2	: 1;
	int p30	: 1;
	int p31	: 1;
}port_t;
typedef union {
	port_t pins;
	unsigned int reg;
} ioreg;
typedef struct {
	ioreg iopin;
	ioreg ioset;
	ioreg iodir;
	ioreg ioclr;
}gpio_t;
So I declare a pinter like
	volatile gpio_t *gpio = 0xE0028000;
If I access the registers using
	if( gpio->iopin.reg & 0x01 )
or
	gpio->ioset.reg |= 0x00008000;
Everithing works fine! But if I try a code like this:
	gpio->ioset.pins.p15 = 1;
To set P0.15, P0.23 and P0.31 are set too! I had tried this code in my Linux
workstaion and it works just fine. The compiles setting I'm using are
arm-elf-gcc -c -Wall -D GCC_ARM7 -mcpu=arm7tdmi -Tlpc2106-rom.ld -Wcast-align
-O3
So I'm compiling it in ARM mode. Any clues? Is this a compiler issue ( I'm not
using the right parameters)?
Thanks a lot!
This is Linux country.
On a quiet night, you can hear Windows reboot.
Leonardo Pereira Santos
Engenheiro de Projetos
PD3 Tecnologia
av. ParĂ¡ 330/202
(51) 3337 1237
Today Fortune tells us:
The most important service rendered by the press is that of educating
people to approach printed matter with distrust.
Re: [lpc2000] C union not working
2005-03-17 by Micron Engineering
Leonardo Santos wrote:
>Hello All:
>typedef struct {
>	int p0	: 1;
>	int p1	: 1;
>	int p2	: 1;
>	int p30	: 1;
>	int p31	: 1;
>}port_t;
>typedef union {
>	port_t pins;
>	unsigned int reg;
>} ioreg;
>typedef struct {
>	ioreg iopin;
>	ioreg ioset;
>	ioreg iodir;
>	ioreg ioclr;
>}gpio_t;
>or
Seems as if the bit field is a short int...
>-O3
>Thanks a lot!
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.7.3 - Release Date: 15/03/2005
2005-03-17 by Robert Adsett
At 12:06 PM 3/17/05 -0300, Leonardo Santos wrote:
>Hello All:
> binutils 2.15
>typedef struct {
>         int p0  : 1;
>         int p1  : 1;
>         int p2  : 1;
>         int p30 : 1;
>         int p31 : 1;
>}port_t;
>typedef union {
>         port_t pins;
>         unsigned int reg;
>} ioreg;
>typedef struct {
>         ioreg iopin;
>         ioreg ioset;
>         ioreg iodir;
>         ioreg ioclr;
>}gpio_t;
>or
P15 is a 1 bit int so its only values are 0 and -1 but I don't think that's
the problem.   Provided your bit order is correct I don't see any reason
they shouldn't give the same result.  I'd use unsigned int for bitfields
unless you wanted them to be signed for some particular purpose.
Hmm, those are 8 bits apart.  Have you taken a look at the assembly output
for the two cases?  They should be similar if not identical. Unless the
compiler is getting confused by some sort of sign extension issue?  Seems a
stretch though.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-03-17 by Anton Erasmus
On 17 Mar 2005 at 12:06, Leonardo Santos wrote:
> Hello All:
>  binutils 2.15
> typedef struct {
>  int p0	: 1;
>  int p1	: 1;
>  int p2	: 1;
>  int p30	: 1;
>  int p31	: 1;
> }port_t;
> typedef union {
>  port_t pins;
>  unsigned int reg;
> } ioreg;
> typedef struct {
>  ioreg iopin;
>  ioreg ioset;
>  ioreg iodir;
>  ioreg ioclr;
> }gpio_t;
> or
> Linux workstaion and it works just fine. The compiles setting I'm
> using are
> -Wcast-align -O3
> I'm not using the right parameters)?
If you are using packed structs, then this will fail. The compiler generates byte
accesses to structures.  The best thing is to look at the assembler output
to see what is actually happening.
  Anton Erasmus
A J Erasmus
Re: C union not working
2005-03-19 by jamesasteres
I don't believe the ARM has bit access instructions.  So when the
compiler reads the ioset register (or a byte of it?) according to
the datasheet you will read what was previously written.  So you
risk setting unwanted pins (likely).
James
--- In lpc2000@yahoogroups.com, Leonardo Santos <lsantos@p...> wrote:
> Hello All:
the P0 pins
> typedef struct {
> 	int p0	: 1;
> 	int p1	: 1;
> 	int p2	: 1;
> 	int p30	: 1;
> 	int p31	: 1;
> }port_t;
> typedef union {
> 	port_t pins;
> 	unsigned int reg;
> } ioreg;
> typedef struct {
> 	ioreg iopin;
> 	ioreg ioset;
> 	ioreg iodir;
> 	ioreg ioclr;
> }gpio_t;
> or
in my Linux
are
Wcast-align
> -O3
issue ( I'm not
> Thanks a lot!
> PD3 Tecnologia
> av. ParĂ¡ 330/202
> (51) 3337 1237
educating
Re: [lpc2000] Re: C union not working
2005-03-20 by Robert Adsett
That's true, but I don't think it's relevant in this case.  IOSET is
documented to read back the last values the port was set to
Should read the current set value for the port and set the 16'th bit and
any other bits that are already set.  While
should logically do the same (after logically doing the appropriate sign
wrapping which ends up being a null operation).  Anton's earlier question
about packed structs is probably very much to the point.  It never occurs
to me that anyone would use packed structs on an architecture that doesn't
support unaligned access.  Certainly accessing any of the peripheral
registers on anything other than a word boundary could cause interesting
results.
Perhaps Leonardo can report back the results of the investigation when it's
finished ?
Robert
2005-03-20 by Arie de Muynck
> results.
it's
> finished ?
> Robert
The GCC compiler tries to optimize the access for bitfields. It combines
multiple sequential set and clear instruction to the same bitfield into one
AND-OR pattern, then determines the minimal necessary width. If that fits
inside one byte, it just changes that single byte, irrespective the width of
the total bitfield.
This is fine for memory (RAM) operations on most processors, even the ARM -
unfortunately  it is deadly to I/O registers that can only be read and
written 32-bits wide.
I've seen a nice example in the NetSilicon NET+ARM BSP, originally written
for ADS using bitfields for the registers, and completely rewritten for all
I/O access to be able to use the GCC compiler.
Arie de Muynck
