Lpc2000
Re: LPC2129 IAP problem solved, sorta. Finally this time :-)
2005-03-21 by yamppman
--- In lpc2000@yahoogroups.com, "Bill Knight" <BillK@t...> wrote:
> On Mon, 21 Mar 2005 14:46:24 -0000, jim_e_dallas wrote:
> --- In lpc2000@yahoogroups.com, "yamppman" <jesperh@t...> wrote:
> > > I have IAP programming running on an LPC2114 at 60MHz.  See
> > > LPC-FlashRoutines-18Feb05.zip in the files section on yahoo.
> > > Note the clock frequency parameter is in KHz (60,000,000 /
1000)
> > > Regards
> > > -Bill Knight
> > > R O SoftWare &
> > > http://www.theARMPatch.com
> > Excellent and useful bunch of code, but it has the same problem.
It
> > works when I disable the PLL and run at 12MHz, but it will not
work
> > at 60 MHz.
> > There seem to be a problem on the 2129 with this.
> > /Jesper
> If your device is an older device, have you upgraded the
bootloader?
> This sounds like the same problem that happened with the original
> boot loader on this device.
> Good idea!  The code in the ZIP file has run for me without
problems
> for some time now.  And the LPC I'm using has the upgraded
bootloader.
It was indeed the bootloader. I was running version 1.6, which I
from another message here, assumed was the latest.
I found the Errata sheet for the 2129 and it mentioned this exact
problem and a version 1.63.
I programmed that onto the CPU, and it works now at full speed.
Thanks for the help.
/Jesper
