Hi Stefano;
How is this accomplished? I mean, I only have two serial ports (COM1
and COM2), and a USB (with two ports) appearing at the device manager
(Window 2000). But in the Philips Flash Utility, it only appears COM1
through COM5, and not the USB ports...
How do you change the port number to really redirects the selected
port to the USB port where the code download will be make?
Thanks in advance;
Gus
--- In lpc2000@yahoogroups.com, Stefano Coluccini <s.coluccini@c...>
wrote:
> Hi,
> I solved the problem changing the COM number from the device
manager.
> Bye,
> Stefano.
> At 16.06 28/03/2005, you wrote:
> >Hi:
> >Has the Philips Flash Utility support for the USB?. If so, is there
> >needed any USB driver? Because, it only shows me COM1 through
COM5, and
> >I have no way to set it up to take the USB PC's interface.
> >Thanks
> >Gus
