LPC Flash Limitations
2005-03-30 by johnthomasedwardtimm
I understand the various limitations concering the internal flash memory. Concering the 16 writes per 4096 bit block limitation, I am doing 32 128-bit writes without problems. What is the potential danger of doing this? Thanks, JT
2005-03-30 by philips_apps
John, the answer is simple, unreliable data :-( A new device will probably not show any proplems but over time data retention will get worse and you could simply loose data. Could work for quite a while but absolutely not recommended (and not specified). Robert --- In lpc2000@yahoogroups.com, "johnthomasedwardtimm" <area51@a...> wrote:
> > I understand the various limitations concering the internal flash > memory. Concering the 16 writes per 4096 bit block limitation, I am > doing 32 128-bit writes without problems. What is the potential > danger of doing this? > > Thanks, > > JT
Robert, Thanks for the reply. Can I write 32 byte (256-bit) chunks 16 times to fill a 4096-bit section? I believe in a previous email you mentioned that 256-bit is the maximum size of a chunk you can write to a 4096-bit row that has data in it already. Thanks, JT --- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...> wrote: > > John, > > the answer is simple, unreliable data :-( A new device will probably > not show any proplems but over time data retention will get worse and > you could simply loose data. Could work for quite a while but > absolutely not recommended (and not specified). > > Robert > > --- In lpc2000@yahoogroups.com, "johnthomasedwardtimm" <area51@a...> > wrote: > > > > I understand the various limitations concering the internal flash > > memory. Concering the 16 writes per 4096 bit block limitation, I am
> > doing 32 128-bit writes without problems. What is the potential > > danger of doing this? > > > > Thanks, > > > > JT
2005-03-30 by embeddedjanitor
I definitely got problems when writing 64 or 32 byte chunks on an LPC2129. After some experimentation I found I could only get reliable behaviour with 512 bytes (didn't test bigger). Typically, I'd see a few wrong bits out of 64kB. This might have been fixed in a more recent bootloader. --- In lpc2000@yahoogroups.com, "johnthomasedwardtimm" <area51@a...> wrote:
> > Robert, > > Thanks for the reply. Can I write 32 byte (256-bit) chunks 16 times > to fill a 4096-bit section? I believe in a previous email you > mentioned that 256-bit is the maximum size of a chunk you can write > to a 4096-bit row that has data in it already. > > Thanks, > > JT > > --- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...> > wrote: > > > > John, > > > > the answer is simple, unreliable data :-( A new device will > probably > > not show any proplems but over time data retention will get worse > and > > you could simply loose data. Could work for quite a while but > > absolutely not recommended (and not specified). > > > > Robert > > > > --- In lpc2000@yahoogroups.com, "johnthomasedwardtimm" > <area51@a...> > > wrote: > > > > > > I understand the various limitations concering the internal > flash > > > memory. Concering the 16 writes per 4096 bit block limitation, > I am > > > doing 32 128-bit writes without problems. What is the potential > > > danger of doing this? > > > > > > Thanks, > > > > > > JT
2005-03-30 by tom_laffey
Hi, I also want to write small chunks to the same sector. I'm using a '2294. The users manual (table 216 in the IAP section of the May 3, 2004 manual and also the 'C' command in the ISP section) shows that the destination address must be 512 byte aligned and that the number of bytes to write is a multiple of 512 bytes. I have tried writing smaller areas within the 512 byte "sectors" by leaving all unchanged bits set (i.e., prefill the RAM buffer with the 0xFF and clear only the required bits.) After struggling with this for some time I concluded that the ECC bytes (checks) are written to flash on a 512 byte boundary basis, regardless of the fact that there is an ECC byte for each 16-bytes of accessible flash. In short, the internal flash does not behave like a conventional flash part. I can program 512-byte blocks and I can erase sectors. In my experience, that's it. Tom --- In lpc2000@yahoogroups.com, "embeddedjanitor" <manningc2@a...> wrote: > > I definitely got problems when writing 64 or 32 byte chunks on an > LPC2129. After some experimentation I found I could only get reliable > behaviour with 512 bytes (didn't test bigger). > > Typically, I'd see a few wrong bits out of 64kB. This might have been > fixed in a more recent bootloader. > > > > > > --- In lpc2000@yahoogroups.com, "johnthomasedwardtimm" <area51@a...> > wrote: > > > > Robert, > > > > Thanks for the reply. Can I write 32 byte (256-bit) chunks 16 times > > to fill a 4096-bit section? I believe in a previous email you > > mentioned that 256-bit is the maximum size of a chunk you can write
> > to a 4096-bit row that has data in it already. > > > > Thanks, > > > > JT > >
