Thanks aumat123
i followed your advice and got the fault actualy SSEL pin was dry
soldered.
Now i am trying to interface MMC card through SPI.
Jeetendra
--- In lpc2000@yahoogroups.com, "Jeetendra Singh" <jeet77_7@y...>
wrote:
> Yes i already Pulled up SSEL to 3v3 by a 47K Resister and not used
> for CS(MMC_CS). I am using another GPIO for the purpose of CS
> MMC_CS).
> Notice that In debugger i seen that after loading data in SPDR ,
SPIF
> sets showing data transmited.
> --- In lpc2000@yahoogroups.com, "aumat123" <angelsp@a...> wrote:
> > You must pull up the SSEL of the SCI that you are using. Seem be
> that
> > the SCI in master mode need that the SSELx must be connected and
> > pulled up externally for correct work.
> > --- In lpc2000@yahoogroups.com, "Mark Crow" <mcrow@p...> wrote:
> > > Is SSEL1 pulled up?
> > > -----Original Message-----
> > > From: Jeetendra Singh [mailto:jeet77_7@y...]
> > > Sent: Friday, April 08, 2005 9:44 AM
> > > To: lpc2000@yahoogroups.com
> > > Subject: [lpc2000] spi in lpc2106
> > > Hi friends
> > > i am working in Lpc2106 and facing problem in spi mdule.
> > > Actualy i am using spi module in master mode. i checked my
> code
> > in
> > > jtag debugger(wiggler in CrossStudio)and found that when
> writing
> > data
> > > to the SPDR register then SPif bit in SPSR also sets showing
> that
> > > data is transmitted.
> > > But the problem is that nither data nor clocks in the MOSI &
> SCK
> > pins.
> > > If some body can help me i will be very thank ful to him.
> > > jeetendra
> > > My source code attached
> > > int main (void){
> > > IOSET=0x80;
> > > IODIR=0x00;
> > > PINSEL0 = 0x00005500;
> > > //Config over
> > > init_spi();
> > > IOSET = MMC_CS; // Chip select High
> > > MmCardSendByte(0xAA);
> > > IOCLR = MMC_CS; // Chip select Low
> > > while (1);
> > > void init_spi(){
> > > unsigned char ch;
> > > IODIR |= MMC_CS; // io direction of mc chip select
> > > SPCCR = 0xfe; // clock counter
> > > SPCR = 0x20; // spi master mode,
> > > // ch = SPDR;// data read
> > > BYTE MmCardSendByte(BYTE bt)
> > > BYTE input;
> > > SPDR = bt;
> > > while (!(SPSR & 0x80));
> > > input = SPDR;
> > > return input;
> > > Yahoo! Groups Links
> > > a.. To visit your group on the web, go to:
> > > http://groups.yahoo.com/group/lpc2000/
> > > b.. To unsubscribe from this group, send an email to:
> > > lpc2000-unsubscribe@yahoogroups.com
> > > c.. Your use of Yahoo! Groups is subject to the Yahoo!
Terms Show quoted textHide quoted text
> of
> > Service.
> > > [Non-text portions of this message have been removed]
