borked serial port in LPC210x ???
2005-04-12 by Pawel Sikora
Hi all,
I wrote a simple program called "serial-echo".
It receiving bytes from PC and sending they back
to the PC. During long time transmissions
received stream is shorter in comparison to the
original stream.
tx rx (bytes)
100 100
1000 1000
10000 10000
20000 ~19983
50000 ~49931
100000 ~99984
The embedded system has a 14.745MHz xtal,
enabled PLL (cclk=60MHz) and mem. acceleration
set up to MAMTIM=2/MAMCR=2.
The serial link is established at 57600,
8 data bits, no parity, 2 stop bits.
inline unsigned __get()
while (!(UART0_LSR & 0x01));
return UART0_RBR;
inline void __put(const unsigned c)
while (!(UART0_LSR & 0x20));
UART0_THR = c;
int main()
initCore(CORE_HIGH_SPEED);
setSerialSpeed(57600);
while (1)
__put(__get());
118:eb000023 bl 1ac <initCore>
11c:e3a00ce1 mov r0, #57600 ; 0xe100
120:eb000270 bl ae8 <setSerialSpeed>
124:e3a0020e mov r0, #-536870912 ; 0xe0000000
128:e2800903 add r0, r0, #49152 ; 0xc000
12c:e5903014 ldr r3, [r0, #20]
130:e3130001 tst r3, #1 ; 0x1
134:0afffffc beq 12c <main+0x24>
138:e5901000 ldr r1, [r0]
13c:e3a0220e mov r2, #-536870912 ; 0xe0000000
140:e2822903 add r2, r2, #49152 ; 0xc000
144:e5923014 ldr r3, [r2, #20]
148:e3130020 tst r3, #32 ; 0x20
14c:0afffffc beq 144 <main+0x3c>
150:e5821000 str r1, [r2]
154:eafffff4 b 12c <main+0x24>
Smiliar echo program works fine e.g. on PIC-18F2620.
Did I missed something?
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
http://smallbusiness.yahoo.com/resources/
