Debuging lpc2138 with GNU-arm-gdb
2005-04-14 by soren_t_hansen
I'm trying to establish a development enviroment to a lpc2138 on the Keil MCB2130 evaluation board. I'm using Eclipse and would like to debug my program using the GNU-arm-gdb. To connect to the board I'm using the Raven OCDemon from Macraigor and their program OCDRemote to interface between JTAG and GDB. But so far I'm having some problems. At first it seemed to work okay using gdb from a shell. But when running in Eclipse it was only possible to pause and resume the program. I tried to erase the flash since the program was also present there, due to earlier tests. But now my program (linked for RAM) will not run at all unless I step my way trough. If I try to "go" the program counter (PC) jumps to address 0x7fffd2a2 and keeps looping there forever. I can't seem to grasp if it something in my program or maybe my linking script that's wrong. Or maybe it's the Raven/ocdRemote/GDB combo that causes the problem. Anyone have had this problem? Has anyone tried debuging in Eclipse through JTAG? Best Regards Søren Hansen
