Lpc2000
Jumping to ISP from user code
2005-05-04 by ukkie9a
Hello everyone,
I have modified the code in the Philips' application note AN10356 for
the purpose of building a simple solution to in-field firmware
updating (over UART0). The idea is that the bootloader does most of
the work. My updates are at http://compuphase.com/lpc2100_isp.htm.
Kind regards,
Thiadmer Riemersma
Re: Jumping to ISP from user code
2005-05-04 by lpc2100_fan
Richard,
can you be (a little) more specific with your "NACK"
Bob
> NACK
> Richard
2005-05-04 by Richard
Bob,
   The link was dead, works now.
Richard
--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@y...> wrote:
> Richard,
> Bob
> > NACK
> > Richard
Re: [lpc2000] Jumping to ISP from user code
2005-05-05 by Rod Moffitt
Once again thanks Thiadmer for a great page.
On a side note, the more recent devices (like the LPC213X) have a new IAP
command to enter the ISP manually, so this hack is not needed (just call
the IAP with the command number '57', IIRC).
- Rod
                          ___  ____  ___    _      ___
  Rod Moffitt            / _ \/ __ \/ _ \  (_)__  / _/__
  http://rod.info       / , _/ /_/ / // / / / _ \/ _/ _ \
  rodANTISPAM@... /_/|_|\____/____(*)_/_//_/_/ \___/
  ~ Where loved ones are remembered http://memoriam.org ~
On Wed, 4 May 2005, ukkie9a wrote:
> Hello everyone,
> Kind regards,
> Thiadmer Riemersma
2005-05-07 by Thiadmer Riemersma (ITB CompuPhase)
Hello Richard,
Sorry, I forgot the "www" part. The full link is
http://www.compuphase.com/lpc2100_isp.htm. I often omit the "www" on
web addresses, because most sites work anyway, but I guess that DNS
lookup may take longer.
Kind regards,
Thiadmer
Hello Rod Moffitt,
> new IAP command to enter the ISP manually, so this hack is not
> needed (just call the IAP with the command number '57', IIRC).
Great! I have been developing most software right now on a developer
board with an LPC2106, but the actual device we are designing is based
on the LPC2138. I have thumbed through the LPC2138 manual a few times,
but I did not stumble on this yet. Now I will go look for it.
Thiadmer
