Lpc2000
Capture pin interrupts, part 2
2005-05-05 by jase_ko
Hi guys,
I have a pin (P0.16) set up as a capture pin CAP0.2 to copy timer0
TC value into CR2 every time I detect a rising edge.
This is done using
PINSEL1 |= 0x00000002;
T0CCR = 0x140;
The value 0x140 for T0CCR sets it up to detect rising edges and
generate an interrupt. My problem is:
I want to record the contents of the CR2 register (ie. the TC when a
rising edge is detected). I know the CR2 register gets the TC value
when the rising edge occurs, however I need an interrupt routine to
copy CR2 to my own data structure. My question is, how do I set up
an interrupt method that is called by the capture pin?
I know it's got to do with VIC, but I'm unsure how to link an
interrupt method, with the capture pin P0.16
eg, how do I link the interrupt method specified at vicvectaddr0 to
occur when the capture pin is triggered by the rising edge?
say I have
T0CCR = 0x140;
VICVectAddr1 = (unsigned long)myCaptureMethod;
How do I make it so the capture pin calls myCaptureMethod?
thanks
