Capture pin interrupt issues
2005-05-05 by jase_ko
Hi guys, I have a pin (P0.16) set up as a capture pin CAP0.2 to copy timer0 TC value into CR2 every time I detect a rising edge. This is done using PINSEL1 |= 0x00000002; T0CCR = 0x140; The value 0x140 for T0CCR sets it up to detect rising edges and generate an interrupt. My problem is: I want to record the contents of the CR2 register (ie. the TC when a rising edge is detected). I know the CR2 register gets the TC value when the rising edge occurs, however I need an interrupt routine to copy CR2 to my own data structure. My question is, how do I set up an interrupt method that is called by the capture pin? I know it's got to do with VIC, but I'm unsure how to link an interrupt method, with the capture pin P0.16 eg, how do I link the interrupt method specified at vicvectaddr0 to occur when the capture pin is triggered by the rising edge? Thanks for any advice, Jason
