Lpc2000
3.5 logic to 5.0
3.5 logic to 5.0
2005-05-06 by javida13
I have a 5 volt logical display that I'm driving.  The Vol for this
part is 3.5 volts (.7*Vcc).  I have 3-signals that must be driven to
this logic level.  Is there a LS type of device that can be used as the
level translator, where is can be powered by 5 volts and its input
level can be driven by 3.3 volt logic?
  Barry
Re: [lpc2000] 3.5 logic to 5.0
2005-05-06 by Robert Adsett
Standard HCT logic.
TI has a good selection.  I still remember fondly the yellow TI logic bible
http://focus.ti.com/logic/docs/bytechnologyfamily.tsp?templateId=5985&navigationId=11386&path=templatedata/cm/ovw/data/hct_overview&technologyFamilyId=16
Other manufacturers, including Philips, should also have a good selection.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
Re: 3.5 logic to 5.0
2005-05-06 by lpc2100_fan
Philips has a good selection too ;-)
http://www.standardics.philips.com/products/hc/all/
Cheers, Bob
> Standard HCT logic.
logic bible
selection.
> Robert
restrictions,   be
chew a
2005-05-06 by Peter Jakacki
Vol ??? You do mean Vih, don't you? In my experience I've never had a
problem with driving 5V logic from 3.3V as the minimum Vih in is
specified for full-speed digital switching. The 3.3V definitely drives
the 5V logic as a logic high but it may not work to "parametric"
specification at 100Mhz etc. For all your normal I/O work it is never a
problem and I don't let myself lose sleep over it.
You can though for peace of mind and sleep use pull-up resistors to +5V
on the output lines and simply simulate open-drain drivers by writing
the IODIR. It doesn't matter if you initially drive them to 3.3V and
then float by switching to inputs with the pull-up. IMO, skip the
buffers, they are always overkill.
my2cents
*Peter*
p.s. Hey Rob! I dug out the TI yellow bible and mine is dated 1988. I
also remember my first logic data book, it was a big red Fairchild
Semiconductor TTL data book from the early '70s. Back then you needed
PSUs that could supply amps, none of this itsy-bitsy pencell battery
stuff! Plus you had to worry about fanout (both the blower type and
driving type).
2005-05-07 by javida13
Yes, I did mean VIH.  I forgot to preview before I posted.  I'm
interfacing to a Futaba LCD Emulator.  Some of the inputs are spec'ed
at 0.8*Vcc and others are at 0.7*Vcc Min.  I checked with an App
Eng at Futaba USA and he indicated that 3.3 volt logic will not drive
the device. Since I only have 3-signals to this device (serial
interface), its probably safe to use a AHCT125 device.  The only
problem is that the data I/O line is bi-directional therefore an
additional GPIO is required for this input.
   Barry
a
drives
never a
+5V
writing
and
> my2cents
> *Peter*
I
needed
battery
> driving type).
this
to
Re: [lpc2000] Re: 3.5 logic to 5.0
2005-05-07 by Richard Duits
You can also use a pull up resistor to 5 volt, and switch the gpio
between low output and input. This works because the GPIOs are 5 volt
tolerant (don't do this with an adc capable pin, see the errata for
explanation).
Richard Duits.
>    Barry
> a
> drives
> never a
> +5V
> writing
> and
> > my2cents
> > *Peter*
> I
> needed
> battery
> > driving type).
> this
> to
> the
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
>       http://groups.yahoo.com/group/lpc2000/
>     * To unsubscribe from this group, send an email to:
>       lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-05-07 by Marko Pavlin (home)
I designed one automatic-test circuit with 3-5V preipheral (device
tested). The MCU was LPC932. I used GTL2000 for level shifting. It
worked fine, even for higher speed signals (SPI).
http://www.semiconductors.philips.com/pip/GTL2000DGG.html
GTL2000 is 22 bit, there are versions with less lines/smaller package.
Mare
> explanation).
> Richard Duits.
> >    Barry
> > a
> > drives
> > never a
> > +5V
> > writing
> > and
> > > my2cents
> > > *Peter*
> > I
> > needed
> > battery
> > > driving type).
> > this
> > to
> > the
