To: lpc2000@yahoogroups.com
Sent: Thursday, May 05, 2005 10:45 AM
Subject: [lpc2000] Re: External Reset vs Power Up
Hi Bob, thanks for the help.
I'll bet you meant 1.31 (\TRST). This signal is not connected on
our board. However, it is driven high by the JTAG gizmo (J-Link).
The other problems are really odd. After an external reset, some of
the I/O pins just don't work. I tried disconnecting 0.18 from other
circuitry, programming it as a gpio output and toggling it a few
times. It works as expected after a power-up but just stays low
after an external reset.
My code doesn't know the difference between a power-up reset and an
external reset. I wonder if the ISP code behaves differently before
it transfers control to my code.
Michael
--- In lpc2000@yahoogroups.com, "lpc2100_fan" <lpc2100_fan@y...>
wrote:
> Hello Michael,
> one possible reason although this might not seem related. If you
have
> an external signal on pin 0.31 that would drive this pin low during
> reset (no matter which reset), the LPC2138 will no longer enable
> JTAG. Please make sure that P0.31 not driven externally (has a
weak
> pull-up) when any reset occurs.
> hth, Bob
> --- In lpc2000@yahoogroups.com, "michael_rubinstein_sar"
> <michael_rubinstein_sar@y...> wrote:
> > I'm debugging a new 2138 based design.
> > If the board is powered up, eveything works as expected.
However, if
> > an external reset (\RESET) is then applied, several funny things
happen:
> > o JTAG stops working.
> > o P0.18 which is configured as a timer capture input, sinks
current.
> > o P0.4 which is used as SPI SCK, in master mode, stops going
high.
> > I verified the values in PINSEL, IODIR and IOSET. They are
correct and
> > the same in both cases.
> > Any help appreciated.
> > Thanks,
> > Michael Rubinstein
Yahoo! Groups Links
http://groups.yahoo.com/group/lpc2000/
