> Is there any way of chosing on what level the interrupt should trigger
> (logic 1 or 0)? As it is now it triggers on 0.
> --- In lpc2000@yahoogroups.com, "frumbub" <j_lilje@h...> wrote:
> > Problem solved!
> > Thanks for the help. (sometimes it helps just to write down the
> > problems ;) )
> > > Yes that stops th infinite loop, but another problem remains.
> > > It seems that the ISR dont returns. The system freezes.
> > > Any ideas?
> > > --- In lpc2000@yahoogroups.com, Richard Duits <yahoo@r...> wrote:
> > > > You need to clear the external interrupt (even with level sensitive
> > > > interrupts) with like in the following code:
> > > > void eint_ISR( void )
> > > > vParTestToggleLED( 0 );
> > > > EXTINT = 1; /* clear EINT0 */
> > > > VICVectAddr = 0; /* acknowledge interrupt */
> > > > Richard Duits
> > > > frumbub wrote:
> > > > > Hello
> > > > > I am having problems with the EINT0 interrupt.
> > > > > I have searched the posts and tried all suggested sollutions,
> but my
> > > > > problem persists.
> > > > > The problem is that the system stays in the ISR like in an
> > > infinite loop.
> > > > > Code:
> > > > > VICVectAddr = ringCLEAR_VIC_INTERRUPT;
> > > > > And thats it... the vParTestToggleLED( 0 ) function just toggles
> > a led
> > > > > one time, that is verified, but when EINT0 is triggered if flashes
> > > > > endlessly and the other processes are blocked.
> > > > > The EINT0 setp code:
> > > > > VICIntSelect &= ~( RING_VIC_CHANNEL_BIT );
> > > > > VICIntEnable |= RING_VIC_CHANNEL_BIT;
> > > > > VICVectAddr2 = ( portLONG ) vRING_ISR;
> > > > > VICVectCntl2 = RING_VIC_ENABLE | RING_VIC_CHANNEL;
> > > > > /* Enable EINT0 interrupt. */
> > > > > PCB_PINSEL1 |= EINT0_ENABLE;
> > > > > Please help me out...
> > > > > *Yahoo! Groups Links*
> > > > > * To visit your group on the web, go to:
> > > > > http://groups.yahoo.com/group/lpc2000/
> > > > > * To unsubscribe from this group, send an email to:
> > > > > lpc2000-unsubscribe@yahoogroups.com
> > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > > > > Service <http://docs.yahoo.com/info/terms/>.
