Lpc2000
Re: FW: [lpc2000] Digest Number 591
2005-05-09 by Peter Maloy
> > From: "James Dabbs" <jdabbs@...>
> > Subject: RE: LPC2132 as DSP processor
> >Compared to dedicated DSP's, I've found the bigger limitation to be
> >ARM's lack of circular buffer management. In a 4-pole IIR filter, I saw
> >most of the CPU BW spent managing pointers and ldr/str'ing rather than
> >doing the actual math.
 Agreed! Whenever I optimise DSP-like code, I concentrate on managing the
data movement; try to use LDM and STM instructions rather than LDR and STR,
possibly interleave history and coefficients, and perform as many operations
in registers as possible between loads and stores - it's possible to perform
four or five FIR or IIR operations in parallel within the ARM's registers.
 Following these principles I was able to get a five-times speedup of a
quite reasonable assembler implementation of a notch filter, though managing
register re-use so that the STM instruction left the results in the right
order for the next call to the function required a couple of days of
skull-sweat.
 This is one of the few situations I've seen where I would justify the use
of assembler over a C code implementation - though I still like having a
proven C implementation available so that I can validate the results
returned by the assembler function. "All software is guilty until proven
innocent".
Peter.
