Lpc2000
OT: 126x64 serial interface graphics modules
2005-05-09 by gregdeuerling
Hello,
Does any one know of someone who manufactures a 128x64 graphics module
with a serial interface?  I've looked around for an hour or so and
have only found parallel interfaces.  I know the KS07xx chipset's
support serial, just can't finds a display that uses it!
Thanks...
Re: OT: 126x64 serial interface graphics modules
2005-05-09 by grantpbt
--- In lpc2000@yahoogroups.com, "gregdeuerling" <egads@f...> wrote:
> Hello,
module
> Thanks...
I'm not sure this is what you are looking for, but try Matrix Orbital
and/or Scott Edwards:
http://www.matrixorbital.com/index.php?cName=lcd-graphic-lcds
GB
RE: [lpc2000] Re: OT: 126x64 serial interface graphics modules
2005-05-09 by Greg Deuerling
>> module with a serial interface?  I've looked around for an hour
>> or so and have only found parallel interfaces.  I know the KS07xx
>> chipset's support serial, just can't finds a display that uses it!
> Orbital and/or Scott Edwards:
Thanks for the link!
Those are all char. Displays, not graphic.  I need a 128x64 graphics
module that has a serial interface.  I'd prefer synchronous over async,
but I'll take what I can get...
Greg Deuerling
Fermi National Accelerator Laboratory
Feynman Computing Center, Room 370, MS 368
P.O.Box 500 Batavia, IL 60510
(630)840-4629     FAX  (630)840-5406
Electronic Systems Engineering Group
Work: egads@...
Personal: gdeuerling@...
Re: [lpc2000] OT: 126x64 serial interface graphics modules
2005-05-09 by Marko Pavlin (home)
gregdeuerling wrote:
> Hello,
> Thanks...
Check em-marin. They have a controller and complete LCD module with
serial interface (I2C):
http://www.emmarin.ch/Products.asp?IdProduct=221
But it's not 128x64 but 102x80.
M.
2005-05-09 by kevinblackmore_nz
I've controlled a display from Displaytech with SPI.
It was the 12864COG.
Their website is www.displaytech.com.hk
I'm sure your aware of this but you need a display that brings out
the PS line. (Parallel/Serial).
Good luck
Kevin
--- In lpc2000@yahoogroups.com, "Marko Pavlin (home)" <mp@h...>
> > Hello,
module
and
> > Thanks...
with
> M.
2005-05-10 by roger_lynx
maybe this pointer below might work for you?
--roger
http://www.tianma.com/graphic_displays/product_table/tm12864n-g.htm
> Hello,
> Thanks...
2005-05-10 by Robert Adsett
Kent Displays recently announced an 1/8 VGA size (240x160) SPI interfaced
module.  I haven't managed to get any more information than that out of
them though.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-05-10 by acbraun
> Hello,
module
> Thanks...
Are you looking for synchronous or async serial?  If it's the
synchronous link the KS07xx part provides, then you can look at the
units from crystalfontz.  They have two different glass sizes and I
believe the larger unit (labeled as compact) uses this controller.  I
haven't used the serial interface, but the parallel does what I've
needed.
2005-05-10 by jamesasteres
I've designed-in custom displays with this resolution.  If the P/S
line is brought out, then serial interface is available.  (Serial is
also limited compared to parallel, I don't believe you can read
display data back from the display).  I seem to recall that there are
some standard products out there with serial capability.
James
> Hello,
module
> Thanks...
RE: [lpc2000] OT: 126x64 serial interface graphics modules
2005-05-28 by James Dabbs
> SPI interfaced
> that out of
> them though.
Also, Optex has several 240x64 displays that support a serial interface.
P/N F-51405GNY-LY-AB is a good example.
