Lpc2000
ADC Interrupts in the LPC2214
2005-05-13 by bmiller_rc
We are trying to use the ADC interrupts in the LPC2214.  We use the
following code and get a ready bit but no interrupt.  Could someone
that has been through this drill take a look.  We have generated
interrupts using the capture registers, but that is about it so
far.  Thanks for the help.
------------- asm -----------------------------------
   /* Setup the Timer1 interrupt service routine address into the
VIC controller... */
    ldr     r0, =VICAddr0RegAddr
    ldr     r1, =do_timer1
    str     r1, [r0]
    /* Setup this channel as being valid (0x20), and configure for
       timer 1 interrupt (0x5)... */
    ldr     r0, =VICCtrl0RegAddr
    mov     r1, #0x25
    str     r1, [r0]
    /* Setup the ADC interrupt service routine address into the
ViController */
    ldr     r0, =VICAddr1RegAddr
    ldr     r1, =do_ADC1
    str     r1, [r0]
    /* Setup this channel as being valide (0x20) and configure for
the ADC interrupt (0x12)
    ldr    r0, =VICCtrl1RegAddr
    mov    r1,  #(0x20 + 0x12)   /* 0x20-enable int, 0x12 -int to
handle */
    str    r1, [r0]
    /* Remap vectors to RAM before enabling interrupts
    ldr     r6,
=RMPCON
    ldr     r5,
=REMAP_2_RAM
    str     r5,
[r6]
    /* Enable interrupts, enter supervisor mode and branch to start
of 'C' code */
    msr     cpsr_c, #0x13       /* I=0 F=0 T=0 MODE=supervisor
    bl
main
*                         Interrupt
exceptions                               *
do_timer1:
        stmfd   r13!, {r12, r14}         /* save r12 & r14 */
        mrs     r12, spsr                /* copy the spsr into r12 */
        stmfd   r13!, {r12}               /* and save to the stack
        msr     cpsr_c, #0x93            /* switch to Supervisor
mode */
        stmfd   r13!, {r0-r3, r14}       /* save Supervisor mode
registers */
        msr     cpsr_c, #0x13            /* enable interrupts */
        bl      TimerInterrupt1          /* go handle the interrupt
        msr     cpsr_c, #0x93            /* disable interrupts */
        ldmfd   r13!, {r0-r3, r14}       /* restore Supervisor mode
registers */
        msr     cpsr_c, #0x92            /* switch back to irq mode
        ldmfd   r13!, {r12}              /* restore spsr */
        msr     spsr_cxsf, r12
        ldmfd   r13!, {r12, r14}         /* restore r12 & r14 */
        stmfd   r13!, {r0-r1}            /* save r0 & r1 */
        ldr     r0, =VICVecAddr         /* update VIC */
        mov     r1, #0xff
        str     r1, [r0]
        ldmfd   r13!, {r0-r1}            /* restore r0 & r1 */
        subs    pc, lr, #0x4             /* return from the
interrupt */
do_ADC1:
mode */
registers */
        bl      ADCInterrupt1           /* go handle the interrupt */
registers */
        msr     spsr_cxsf, r12
        mov     r1, #0xff
        str     r1, [r0]
interrupt */
*                        End of startup and interrupt
code                    *
----------C language setup----------------
#define INTERRUPT_5       0x00000020
#define INTERRUPT_18      0x00040000
void InitializeInterrupts()
    /* Disable all interrupts to VIC */
    REG( VICIntEnClear ) = 0xffffffff;
    /* Set VIC to only handle IRQ and not FIQ */
    REG( VICIntSelect )  = 0x00000000;
    /* Now enable the desired interrupts */
    /* Enable Timer1 and ADC interrupt to VIC */
    REG( VICIntEnable ) = INTERRUPT_5| INTERRUPT_18;
//Setup the ADC
void AINSelect(void)
    REG(ADCR)  = 0x00200001;
    REG(ADCR) |= 0x01000000;
    iAIN = 8;
